hey guy's was wondering what i need too do too swap my hz ute over too a auto? apart from the changing the gear box itself, what else will i have too change/swap/replace? cheers
Pedals (including accelerator if it is an electric kickdown Tri), shifter, Park/Neutral and Reversing Switches, Auto Radiator (or Trans Cooler), flex Plate instead of Flywheel. That's all I can think of at the moment.
Cheers...Dave
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
You'll also need a console unless you wan't column shift, then you will need the column and column indicator as well plus the park/neutral and reversing switches on the column. You will also need to remove the clutch pedal. If it's a 6cyl you'll need to r |
