80737k Offline
#1 Posted : Tuesday, 20 December 2005 11:14:16 PM(UTC)
80737k
Two or three months ago, a mate was denied a R.W.C. because he was using lowering blocks; i told him they were legal, he knew this and argued with the mechanic. ended up taking them off to shut the idiot up.
Now i'm fast approaching rego time on my parts chaser, it's running lowering blocks and i'll be damned if i'm going to roll over on this.
What i need to know is A/ Where can i confirm the actual ruling on lowering blocks and B/ Who do i go to if the mechanic doing the R.W.C. says he wont pass the car because of the lowering blocks?
I know it'd be easier to just remove them for the test but NOT AN OPTION.
If anyone has had this fight before or knows where i can check things, i'd like to hear from you. thanks in advance.
Ooroo
Fossil fuels are YUMMY !
#2 Posted : Thursday, 22 December 2005 4:36:09 AM(UTC)
Well its as plain as the nose on your face mate.
A: Go see your transport department and get a ruleing on wether the lowering blocks are legal.
B: Go see an engineerer and have all the modifications psssed.
C: Go buy the latest Toyota Corolla and have
Dylan Offline
#3 Posted : Thursday, 22 December 2005 5:09:33 AM(UTC)
Dylan
i had my HQ ute (now a full body off project) looked at for a RWC and they didnt like the rust holes in the rear quarters the dodgy tie rod ends and the way i put the battery cable to the starter in, but didnt say anything about the 2" lowering blocks in
bluHJ Offline
#4 Posted : Thursday, 22 December 2005 8:26:05 AM(UTC)
bluHJ
They are legal. They must be made of metal and have the locating pins for the spring and axle. The U bolts cannot be extended and must be made of 1 piece.
I note from your profile that you are from Vic. If you have trouble, ring 03 9380 7269 and
Edited by user Thursday, 22 December 2005 8:27:33 AM(UTC)  | Reason: Not specified
#5 Posted : Friday, 23 December 2005 4:41:44 AM(UTC)
i have heard that theres not problem with lowering block. i used to run them also. i put a healty 350 into my Van. took it to Eastern Creek dragway. wound it up and snapped both U bolts. they were brand new high tensile steel. They should be banned. if th
