ITCH Offline
#1 Posted : Saturday, 29 May 2010 4:42:10 AM(UTC)
ITCH
I have a 307 Chev block, cast # 3914636 Engine # 307xxxx1 k1019, was told it was pulled from a HK Monaro ....? anyone got any clues ?
CHEERS!!
< Gotta Luv It!
Edited by user Saturday, 29 May 2010 7:11:55 AM(UTC)  | Reason: Not specified
<b><font color="orange">&lt; 4 SALE , SELLING .......SOLD!</b></font id="orange">
Mr.Jones Offline
#2 Posted : Saturday, 29 May 2010 4:48:47 AM(UTC)
Mr.Jones
You will need to provide the numbers after the 307 that will tell you what plant and time frame it came from.
Leroy
Voltaire
Voltaire
#3 Posted : Saturday, 29 May 2010 7:23:41 AM(UTC)
its from a WRECKED parisienne HAHAHAHHAHAHAHAHAHAHAAHAHHA
ITCH Offline
#4 Posted : Saturday, 29 May 2010 8:23:01 AM(UTC)
ITCH
Good stuff WRECKED , must be super rare then !! cause no Parisienne came with a 307 engine ......HAHAHAHAHA! http://en.wikipedia.org/wiki/Pontiac_Parisienne
CHEERS!!
< Gotta Luv It!
#5 Posted : Saturday, 29 May 2010 9:00:03 AM(UTC)
lololo, ummm WRECKED HJ stato?? lolol
#6 Posted : Saturday, 29 May 2010 9:44:33 AM(UTC)
Was thanked: 618 time(s) in 584 post(s)
Could be from any HK, most likely Brougham.
ITCH Offline
#7 Posted : Saturday, 29 May 2010 10:07:27 AM(UTC)
ITCH
So its a HK block and worth sweet F A ??
< Gotta Luv It!
petaus Offline
#8 Posted : Saturday, 29 May 2010 5:46:15 PM(UTC)
petaus
stick it e bay tell em it,s from a monaro instantly worth 20 grand, wait till i put my super rare hk monaro front bench seat on there the punters will go crazy.
pete. lol
#9 Posted : Saturday, 29 May 2010 6:06:16 PM(UTC)
Possibly not Monaro as 307 was available from 1/1/68 through to Monaro/Brougham release, and could be HT also. Depends upon the engine number. Worth something, but not huge $.
80569K Offline
#10 Posted : Sunday, 30 May 2010 2:24:51 AM(UTC)
80569K
This has been brought up before, if you want it nailed down you will have to quote the whole engine number except for maybe the last 2 digits eg, 307123##. With that info the guru's will tell you which plant originally installed it in what time period.
AFAIK the 307 prefix indicates a Holden installed engine and K1019 means McKinnon engine plant in Canada and Oct 19. It will probably be 1967 rather than 68 which would make it as Byron said HK pre Monaro.
petaus Offline
#11 Posted : Sunday, 30 May 2010 3:15:24 AM(UTC)
petaus
how many code have been found for the hk 327 e.g T0405 ?
#12 Posted : Sunday, 30 May 2010 5:57:09 AM(UTC)
6 I think for the Tonnawanda HK engines, but not totally sure. Lots more for the later McKinnon ones.
ITCH Offline
#13 Posted : Sunday, 30 May 2010 10:50:05 AM(UTC)
ITCH
Thanks All , I just put it in the scrap bin along with a few other 327 and 350 blocks , take up to much room .
CHEERS!
< Gotta Luv It!
#14 Posted : Sunday, 30 May 2010 7:47:18 PM(UTC)
If it is from a Monaro it would be from an vey early, pre production pilot run Sydney car.
I make it about May 68.
Warren
#15 Posted : Sunday, 30 May 2010 9:34:57 PM(UTC)
Warren, curious as to why a 1019 date assembly code has to be from a very early HK Monaro? I've found plenty of October 1967 dated engines in the mid-high 12000's eg 1018, 1019, 1024.
#16 Posted : Monday, 31 May 2010 2:21:07 AM(UTC)
Byron, I said "if it was from a Monaro" not that it was from a Monaro. High 12000s are early production Monaro so low 12000s would be too early to be normal Monaro.
As for date code, some of these engines sat for a long time at the bend. Lognest known is a first type 327 enigne fitted to an Impala or Pontiac in 70 or 71.
Warren
#17 Posted : Monday, 31 May 2010 2:28:38 AM(UTC)
I'm still confused though. All we have is that it was a 1019 assembly date. I just assumed that you musn't have seen too many of these in Monaros. ITCH's may not even be a Pagewood engine though.
