#1 Posted : Wednesday, 21 December 2005 12:53:38 AM(UTC)
hi guys.
took the "future" HG (not HT like i first thought) for a blat on the weekend and i noticed at idle, when warm, the oil light is on.
when i rev it a bit and bring the revs up about 150-200rpm in drive, it disappears. oil light doesn't come on at all otherwise other than just before starting.
is this a common 186 prob or is the idle just set too low? it "sounds" about right, maybe a touch low, but add the 200rpm with th accelerator and it feels too fast.
what do i do?
think more, post less.
80737k Offline
#2 Posted : Wednesday, 21 December 2005 1:00:17 AM(UTC)
80737k
don't take my word for it but if your oil is from coles or just getting old, you might want to change it and see what happens, might be it.
Ooroo
Fossil fuels are YUMMY !
#3 Posted : Wednesday, 21 December 2005 1:33:56 AM(UTC)
The first time I took my HZ 253 out for a run to the city I almost died as the oil light came on when stuck at the lights after I had been driving for some time. Apparantly I found out that most old Holdens have this problem, at Idle the oil preasure get
trubluhq Offline
#4 Posted : Wednesday, 21 December 2005 2:01:40 AM(UTC)
trubluhq
I agree with the guys. Are you using crap el cheapo oil ? If you buy Shell, Caltex, Valvoline...you get what u pay for! Fact.
Penrite is THE ONLY oil for my 2 Holdens. Nothing else WILL EVER be used.
Rgds John
80737k Offline
#5 Posted : Wednesday, 21 December 2005 2:11:50 AM(UTC)
80737k
Not going to knock any brands of oil but i'll stand by Penzoil, It's the only oil i've ever bothered with.
Ooroo
lonemonaro Offline
#6 Posted : Wednesday, 21 December 2005 2:47:09 AM(UTC)
lonemonaro
Hi all,
Could it be a faulty engine oil switch that gives intermittent readings ?
I would stick to the correct viscosity that the manufacturer suggests for any particular motor. However there are some good oils on the market now, so it's up to the i
#7 Posted : Wednesday, 21 December 2005 3:52:17 AM(UTC)
ah okay - so the pressure is getting low when warm at idle.
and it is only at idle when at operating temp. doesn;t come on when cold idling (on gas so no choke)
i had a feeling that a thicker grade oil may help - but yeah i normally use Penrite for
#8 Posted : Wednesday, 21 December 2005 9:19:53 AM(UTC)
G'day I have seen this problem a few times over the years in my workshop. The oil pump sounds worn to me, reason being the light only comes on when the engine is warm and the oil thins out.If u had a restriction it would be worse when the engine is cold a
#9 Posted : Wednesday, 21 December 2005 12:18:25 PM(UTC)
Don't fret. The Holden factory shop manual states this is perfectly acceptable as long as the light goes out when the revs go just above idling. It is part of the imperfect switch for the light, at idle the pressure is only about 4 psi and some switches d
#10 Posted : Wednesday, 21 December 2005 10:02:53 PM(UTC)
thanks for that.
oil pump is brand spankers (well, about 20thou old) so it's not that.
if the manual says it's normal then i'll just run slightly thicker oil and see what difference it makes.
cheers for all your help.
