CrustyHK Offline
#1 Posted : Saturday, 5 June 2010 8:09:42 AM(UTC)
CrustyHK
I reckon this will be a simple one for you guys again
Are the HK bonnets the same as HT-G?
Pete
OH PS: Apart from the scallop in the quarter panel where it lines up with the door line, is there any differences in the quarters?
Edited by user Saturday, 5 June 2010 8:12:26 AM(UTC)  | Reason: Not specified
65ehpv Offline
#2 Posted : Saturday, 5 June 2010 1:01:49 PM(UTC)
65ehpv
The coupe bonnets are different. The HT & HG have the flutes/scoops. The sedans, wagons, panelvans and utes would be the same
Carpe Diem
Carpe Diem
#3 Posted : Saturday, 5 June 2010 6:07:08 PM(UTC)
The bonnets will interchange, there are 2 basic types (with & without scoops) but there are other differences if you are fussy.
HT bonnets have cut-outs in the inner frame where the H-O-L-D-E-N letter's mounting pins protrude near the front.
Likewise for HG, they made cut-outs for the script badges in the LHS front edge.
There are many types of rear quarter panels, HK tail-lights different (for all body styles) & the roofline is totally different to HT-G (Kingswood & Belmont). Premier & Brougham have different roofline again. Coupes different off course.
The best argument against democracy is a 5 minute conversation with the average voter.
#4 Posted : Saturday, 5 June 2010 7:27:48 PM(UTC)
Was thanked: 620 time(s) in 585 post(s)
Wheelarches are slightly different in HK as well, except Monaro.
CrustyHK Offline
#5 Posted : Saturday, 5 June 2010 8:05:58 PM(UTC)
CrustyHK
Thanks all
Byron is the difference in the arches clear? I have NOS HT Brougham quarters to put on the HK Brougham and for the life of me I can't spot a difference in the arches.
I cut the old quarters off below the scallop so that the body line through the door matches.
#6 Posted : Saturday, 5 June 2010 9:20:27 PM(UTC)
Not sure about Brougham. They may be the same as they were introduced when HK coupe was introduced, and HK coupe was the first to get HT style wheelarches.
CrustyHK Offline
#7 Posted : Sunday, 6 June 2010 1:41:56 AM(UTC)
CrustyHK
Ahhh fair enough. I sat the HT quarter against an HK and they seem identical so that must be the case.
petaus Offline
#8 Posted : Sunday, 6 June 2010 4:07:11 AM(UTC)
petaus
does anyone know where the panels were stamped, meaning if the monaro shells were made in adelaide and brisbane, where the panels pressed there meaning to sets of dies for the rear quarters or did they come from another plant, and just welded in adelaid and brisbane? where was the stamping plant in that era?, some one told told me bonnets and front guards were made at the plants cause they were same across the model range etc for gts of course this was hq hj hx era
pete.
#9 Posted : Sunday, 6 June 2010 4:37:55 AM(UTC)
Sydney made probably the most HK-HG coupe shells, and Brisbane, Adelaide and Melbourne did them too. AFAIK all panel pressings were made in the same place and assembled at the above 4 x plants. Dr Terry will confirm or deny.
petaus Offline
#10 Posted : Sunday, 6 June 2010 4:54:29 AM(UTC)
petaus
i was under the impression that hk monaro body were only welded together at adelaide and brisbane, adelaide ones went to melbourne and brisbane ones to sydney and finished there???
#11 Posted : Sunday, 6 June 2010 5:49:33 PM(UTC)
The letter at the end of the chassis number indicates the plant that welded the body together, the letter under it represents the plant that finished it.
Have seen M, B, S and A on them. At this point in time no Monaro coupe has been found with a P underneath. (Perth was only a final assembly plant not a body plant). It is beleived that they did not assemble coupe bodies.
Warren
#12 Posted : Sunday, 6 June 2010 7:29:46 PM(UTC)
Adelaide stamped out panels at Woodville and Elizabeth plants
#13 Posted : Sunday, 6 June 2010 7:39:51 PM(UTC)
This was my belief also. I believe that Elizabeth took over these duties from Woodville in the mid 1960s, can you confirm cloudy ?
Why would they have more than 1 pressing plant. It's a bit like the engine plant situation, one place of manufacture (Fisherman's Bend), shipping to all the assembly plants. The cost of tooling is too expensive to have duplicates.
petaus Offline
#14 Posted : Monday, 7 June 2010 7:13:28 AM(UTC)
petaus
so every plant built every style of body?? sedan,premier ,ute, wagon van? except no monaros in perth?
pete.
