#1 Posted : Monday, 26 December 2005 7:23:17 AM(UTC)
Guys
The Overlander just developed a smoking habit. Will look further tomorrow but I think I know the answer, but wanted to check first. It drives fine, but under slow acceleration in second gear it does hesitate slightly. It's a 308 TH400 on LPG/petrol. What is happening is that when I'm travelling downhill for a while running under engine braking it starts to pour smoke out the tailpipe, like it's got a bushfire behind the diff. It has a canvas canopy on it at the moment, but the smoke looks to be white or blue from what I see. I'm thinking buggered auto trans vacuum modulator sucking oil when under high vacuum (ie light throttle). Has anyone busted one of these and had similar symptoms?
trubluhq Offline
#2 Posted : Monday, 26 December 2005 7:56:58 AM(UTC)
trubluhq
Greetings and Salutations !!!!!!
Hmm I think you have it in one !! High vacuum, whiteish smoke. Check ur plugs by manifold bank and tranny fluid level.
Maybe put a clear piece of tube (brake bleeding hose stuff) on the vacuum hose to the tranny and
#3 Posted : Tuesday, 27 December 2005 3:56:12 AM(UTC)
Bugger. I'm about to change engines and would rather it be rings! The modulator is modified on an Overlander to clear the front tailshaft, so I have to modify a new one. As soon as I saw the smoke the first time I sort of guessed modulator though.
