#1 Posted : Monday, 26 December 2005 9:14:11 PM(UTC)
Hello Everybody,
I want to weld a pair of HT Holden engine mounting brackets to a hot rod engine tube.
I have been told to remove an old pair from a crossmember but I would like to use new material so does anyone in the Holden spare parts industry know if they are available new.
Elvis.
EAP
#2 Posted : Monday, 26 December 2005 10:15:47 PM(UTC)
i don't know off hand who may produce them but if you are attaching the chassis side of standard HT mounts to a tube will they be in the correct position anyway? unless the tube mounting point sits in the exact same position (compared to the motor) as the
Edited by user Monday, 26 December 2005 10:16:28 PM(UTC)  | Reason: Not specified
ozchevy Offline
#3 Posted : Monday, 26 December 2005 10:40:14 PM(UTC)
ozchevy
You've jumped the gun with this, Your going to have to sit the block with old engine mounts in position mounted on a trolley jack, level every thing up making sure the chassis also is on a level playing field.
With this all done, you then build the cross
#4 Posted : Tuesday, 27 December 2005 2:13:47 AM(UTC)
Hi OzChevy,
Yep done all as per your reply, I have the engine tube to suit the Plymouth have the engine block and TH350 suspended from the mobile engine hoist. I have to HT crossmember tacked in place, the Commodore rear ends in place now its time to add
Dylan Offline
#5 Posted : Tuesday, 27 December 2005 3:18:50 AM(UTC)
Dylan
assuming you mean the bit that is actully welded to the crossmember i would just make up new ones. pretty easy to make.
#6 Posted : Tuesday, 27 December 2005 4:05:27 AM(UTC)
Rare spares used to make weld on mounts to suit red motors into pre EH Holdens. These should do the same job as red 6's and 253/308's sit on the same crossmember mounts.
#7 Posted : Tuesday, 27 December 2005 7:19:14 AM(UTC)
Hi Bryon,
I'll get onto Rare Spares and get a new pair of mounts while im at it.
Elvis
EAP
#8 Posted : Tuesday, 27 December 2005 7:25:29 PM(UTC)
I couldn't find them on this site, but I know they used to have them. I think I got some years ago from American Auto Parts in Homebush.
