David Offline
#1 Posted : Sunday, 20 June 2010 8:18:28 AM(UTC)
David
Hi fellas,
Took the Chrysler in for service and the repairer told me it has a leaking timing cover due to corrosion (It also covers the water pump). New part is over $1800 (No typing error). I'm looking for a wrecking yard part, but I'm also wondering whether the cover could be welded or braised to repair it. It is Aluminium of alloy. Haven't taken it off for a close look.
Has anyone tried this?
Had to laugh when the wrecker told me he could sell me a 65000 km motor with warranty for $1200. Certainly a better deal than $1800 for a timing cover, but I don't want to store a spare motor.
David
Jvanner Offline
#2 Posted : Sunday, 20 June 2010 10:12:18 PM(UTC)
Jvanner
look up aluminium welders in the phone book and have a chat with them
#3 Posted : Sunday, 20 June 2010 11:45:25 PM(UTC)
Good advice by Jvanner,also another thought is to take it to a wheel repair place as they weld alloy components all the time(wheels and such)
I'm sure they'll do it for alot less than the above figures.
Jim in Adelaide...WTB CENTER LINE AUTO DRAGS 15X7 UPTO 8.5 WIDE.
David Offline
#4 Posted : Monday, 21 June 2010 8:04:57 AM(UTC)
David
Thanks Jim and Jvanner.
Got nothing to lose by giving it a shot! And I'm sick of paying Chrysler.
They wanted $575 for an external mirror. An after market one from US on ebay was going to cost $25.95 plus postage. In the end, I found a Loctite superglue that repaired the broken bit.
David
#5 Posted : Tuesday, 22 June 2010 2:59:48 AM(UTC)
david, many US cars shared parts like this
see if you can find a part number on the timing case somewhere, put this number into a google search
you might be surprised what you find!
David Offline
#6 Posted : Tuesday, 22 June 2010 4:03:15 AM(UTC)
David
Thanks again fellas,
I'll put all the irons in the fire.
mickSP Offline
#7 Posted : Tuesday, 22 June 2010 11:27:34 PM(UTC)
mickSP
Dave,
If you have a 318-360 SB go to
www.sparesplanet.com/gen...0-timing-case-cover.html
Its $220 for a brand new one, i will set a code up for you so you get 10% off that price at the check out,, will save you $20, this will also work across the whole site giving you 10% off anything on the site.. CODE is fastlane10 i will leave the code open for 7 days so if anyone from fastlane wants 10% off just use the code.
Dave if you have a big block, pressed metal T/C covers are $50.00 brand new,,, go figure that!.
www.sparesplanet.com.au/performance
Edited by user Tuesday, 22 June 2010 11:31:18 PM(UTC)  | Reason: Not specified
Guest (5)
