nzstato Offline
#1 Posted : Friday, 25 June 2010 10:37:21 PM(UTC)
nzstato
Just a few Qs, while painting acrylic and its cold what is the recommended mix with thinners? Thicker or thinner? Should I paint the front subframe with black enamel or is acrylic sufficient to withstand a bit of road crap?
Absinth Offline
#2 Posted : Saturday, 26 June 2010 3:13:39 AM(UTC)
Absinth
Don't paint when it is cold unless you have heat lamps or the paint will blush... (go milky) I made that mistake many many years ago re-painting my Charger red, went down to the shed the next morning to remove the masking only to find the car was almost white...
nzstato Offline
#3 Posted : Saturday, 26 June 2010 5:03:58 AM(UTC)
nzstato
Rightoh, I've got a pair of 500W lamps that should do the trick, its just going to be the firewall and subframe that I do anyway. Anyone have ideas on the paint to use for the frame?
#4 Posted : Monday, 28 June 2010 5:43:30 AM(UTC)
Enamel is far easier to get a nice shine straight off the gun which is much easier to deal with than buffing a chassis. Then again if you are painting flat or satin black then acrylic gets the advantage because it dries much quicker.
Vandals and graffiti "artists" do everyone a favour and target parking meters and fixed speed cameras only.
