#1 Posted : Saturday, 31 December 2005 9:08:43 AM(UTC)
hi all thanks for the info on compliance plate nos helps heaps to know what i have actually got or should have. now comes the rebuild.
it has electric windows and they are all very slow and sticky what is the likey problem and best fix,
http://photobucket.com/albums/c8/potfare/?
#2 Posted : Saturday, 31 December 2005 11:54:09 AM(UTC)
There are 2 likely problems.
One is a build up of old grease and dirt in the window winder mechanisms inside your doors. The main reason Electric Windows stuff up is that peopel don't use them, so the grease on the mechanisms dries out a bit and the me
potfare Offline
#3 Posted : Wednesday, 4 January 2006 6:52:08 PM(UTC)
potfare
potfare Offline
#4 Posted : Wednesday, 4 January 2006 6:53:32 PM(UTC)
potfare
crowe Offline
#5 Posted : Thursday, 5 January 2006 9:15:52 AM(UTC)
crowe
Try all the above, but also on the doors just below the locking meck, there's a phillips screw that holds the window runner. lossen this a few turns and move the glass up and down a few times so it self centres the runner. This is to ajust the runner and
HZ-GED Offline
#6 Posted : Thursday, 5 January 2006 10:17:48 AM(UTC)
HZ-GED
I found the graphite powder works a treat. Can get a bit messy if you don't use it properly. Don't use any WD40 or CRC as you will get dirt and crap stuck in the channels.
The powder is available at most good auto stores.
Cheers;
Geoff
#7 Posted : Thursday, 5 January 2006 1:28:29 PM(UTC)
You can get stuff called Dry Lube in Hardware stores and, probably, Target/BigW, etc.
It is also good for sticky desk drawers, etc as it doesn't attract dust.
As HZ Ged said, don't put anything oily/sticky on the Bailey Channel as it will attract di
This page was generated in 0.108 seconds.
