nessyhk Offline
#1 Posted : Sunday, 27 June 2010 3:50:52 AM(UTC)
nessyhk
You have been a member since:: 16/10/2009(UTC)
Gday all, could anyone tell me if a VH disc brake diff would suit a HK prem after all the adjustment where made
Nessyhk
Built not Bought
Nessyhk
Built not Bought
nessyhk Offline
#2 Posted : Sunday, 4 July 2010 11:45:09 PM(UTC)
nessyhk
Gday all surely someone out there can tell me if a vh sle v8 diff will fit into a hk prem.
Nessyhk
Built not Bought
Nessyhk
Built not Bought
htmunro350 Offline
#3 Posted : Monday, 5 July 2010 4:58:18 AM(UTC)
htmunro350
just run a measuring tape over the commy diff and see if u come close to your standard 1 then get some diff saddles off your standard diff put them on and away u go as u know im doing it to the munro with the comaro diff catch up with me i will help if i can
cheers shaun
cheers shaun
nessyhk Offline
#4 Posted : Monday, 5 July 2010 6:49:05 AM(UTC)
nessyhk
Cheers shaun, will do. Then we can dummy yours up aswell
Nessyhk
Built not Bought
Nessyhk
Built not Bought
dirty davo Offline
#5 Posted : Saturday, 24 July 2010 7:33:47 AM(UTC)
dirty davo
vb to vk com 5litre diff is a good choice( 4.2 lit & 6cyl type are smaller guts) to put in hk ht hg.
com 5lit axles are heaps thicker & all 28 fine spline
they are 13mm shorter each side (& are the hq j x z type internals)
only problem is, most sle models are 2.78 or 2.60 ratio, which is ok for over 120klm cruising, but unecomomical under that speed, & carrier is different to 3.08 & higher ratios)
308 lsd is reasonably common in these but most are flooged beyond rebuild thesedays!
i fit these into hk ht hgs all the time (obviously cut all the brackets off & weld saddles in place to suit hk ht hg track.)
(i dont bother with disc crap (as not much advantage, although h/brake cables are now available to adapt, for cuppla hundred bux
but also have to change pipe ends to metric to suit.)
BEST way to go is to just fit hq backing plates on with all standard hq rear drums,(drill to com stud size) shoes & w/cyls, & brake pipes.
then fit your original hk ht hg h/brake cables.
then hq discs & callipers up front.
then drum type axle seals & ya ready ta go
oh & get hq ute/van/statey v8 t/shaft shortened to suit(coz they are 2.5mm wall instead of 2mm)cost about 90 bux to cut & balance plus unis
then its compatable with original ktg booster & m/cyl as is!
this then gives you easily accessible parts you can do road side repairs & just buy std stuff from bursons or repco or wreckers etc.to maintain without modifying anything else
any hq - z internals are easily obtained & can change ratio s to suit
its all heaps easier than it sounds, once done
youl just have metric nuts for rear & std nuts for front
any more info, dont hesitate to contact dirty davo
HK HT HGs. i drive em every day! why would you bother updating?
easily maintained & can use & abuse like no other!
HTs rule 4eva
70htprem Offline
#6 Posted : Saturday, 24 July 2010 9:42:26 AM(UTC)
70htprem
hear hear Davo, T's just drive better than K tractors and more bling than G's. I believe they are rarer too?
Hope these guys send you a little something for your amazing insight.
I know. It's not just a livelihood, it's a PASSION!!!
Remember,,,Don't hide them, Drive them!! :-)
nessyhk Offline
#7 Posted : Monday, 26 July 2010 1:49:49 AM(UTC)
nessyhk
Thanks dirty dave,havent had much of a chance to get on here and source more info on the diff i scored, or to get the advice i need as we have just had a new baby boy added to the household on 14-7-10.will certainly get in contact again once home with the grinder in my hand.
Also still looking for early model hk doors i did ring you a while ago aswell as a hk bootlid have no worries cod anything as i am out in the middle of nowhere,
Cheers Don
Nessyhk
Built not Bought
Nessyhk
Built not Bought
70htprem Offline
#8 Posted : Monday, 26 July 2010 3:02:20 AM(UTC)
70htprem
Congratulations! Hope everyone is doing well.:-)
nessyhk Offline
#9 Posted : Tuesday, 27 July 2010 6:41:33 AM(UTC)
nessyhk
Thanks 70htprem,just finished the hike back from broken hill,still got a week off so maybe i might be able to track down those doors and bootlid i need
Nessyhk
Built not Bought
Nessyhk
Built not Bought
Guest (5)
This page was generated in 0.132 seconds.
