HQwagon202 Offline
#1 Posted : Thursday, 1 July 2010 4:39:56 AM(UTC)
HQwagon202
My wifes EB Fairmont is causing us some dramas as far as fan belt noise.
We have changed all the belts and still a loud noise eminating from the engine area can be heard, mechanic says pulleys are all ok.
What else could be causing the problem.............it is driving us crazing with the noise
kind regards
John
Edited by user Thursday, 1 July 2010 4:40:54 AM(UTC)  | Reason: Not specified
#2 Posted : Thursday, 1 July 2010 7:55:18 AM(UTC)
check the fan is not loose or has damaged or loose blades.
Paul351xb Offline
#3 Posted : Thursday, 1 July 2010 10:22:18 PM(UTC)
Paul351xb
This might sound a bit silly but I had a similar problem once. Thought it was fan belts or a pulley. Turned out to be the distributer. If all else has failed try listening there.
Support female jelly wrestling. We can stop men going to war and solve world hunger all at the same time.
BIGCAV Offline
#4 Posted : Thursday, 1 July 2010 11:47:11 PM(UTC)
BIGCAV
could be the bearings in the water pump etc too, hard to say without being there personally
do u know how to use a long screwdriver as a stethescope?
#5 Posted : Friday, 2 July 2010 1:29:54 AM(UTC)
Another method of diagnosis in addittion to what BigCav has suggested is remove the three belts one at a time and see which removed belt makes the noise go away.
The bearings in the idler pulleys tend to die every couple of hundered thousand KM.
Vandals and graffiti "artists" do everyone a favour and target parking meters and fixed speed cameras only.
#6 Posted : Thursday, 8 July 2010 7:33:51 AM(UTC)
good one i haven't heard that one before
what i use is a peice of garden hose about 1m long, put 1 end to your ear and move the other end around the suspect area
just be very carefull when doing this around a running engine!!!
6pak Offline
#7 Posted : Friday, 9 July 2010 7:29:29 AM(UTC)
6pak
My old EA had a similar noise which turned out to be the idler pulley bearing...on the bright side it's an easy fix. :)
This page was generated in 0.082 seconds.
