Whats the go exactly?
Does VE fit on earlier models? or is it that the earlier stuff won't fit on VE?
Wanted : HJ statesman Rear venetian blind aus wide |
VE hub diameter is smaller, so it needs to be drilled out to suit pre VE models.
And I did read somewhere that they went up from a 12mm stud to 14mm stud.
VE have a smaller spigot than VB-VZ.
VE wheels need to be machined out to fit earlier models.
Other problem is the M14 VE wheel studs. This prevents pre-VE wheels being fitted to a VE (as they will go over the VE's smaller hub), but they also present a prob when you want to run VE wheels on pre-VE with the 12mm studs - there's not enough metal in the tapered seat to press against, so you need either different inserts (with a 12mm hole) or nuts with a much larger taper.
thanks, occasionally i step out of the 1970's!
hmmm, think i gotta step out of them as well sometimes "To remove donuts from wanting to own and drive HO's, God made Monaro's."
