adam PERTH Offline
#1 Posted : Wednesday, 21 July 2010 8:48:08 AM(UTC)
adam PERTH
Whats the go exactly?
Does VE fit on earlier models?
or is it that the earlier stuff won't fit on VE?
Wanted : HJ statesman Rear venetian blind aus wide
Big Al Offline
#2 Posted : Wednesday, 21 July 2010 9:03:00 AM(UTC)
Big Al
VE hub diameter is smaller, so it needs to be drilled out to suit pre VE models.
And I did read somewhere that they went up from a 12mm stud to 14mm stud.
#3 Posted : Wednesday, 21 July 2010 9:10:46 AM(UTC)
VE have a smaller spigot than VB-VZ.
VE wheels need to be machined out to fit earlier models.
Other problem is the M14 VE wheel studs. This prevents pre-VE wheels being fitted to a VE (as they will go over the VE's smaller hub), but they also present a prob when you want to run VE wheels on pre-VE with the 12mm studs - there's not enough metal in the tapered seat to press against, so you need either different inserts (with a 12mm hole) or nuts with a much larger taper.
adam PERTH Offline
#4 Posted : Wednesday, 21 July 2010 9:14:32 AM(UTC)
adam PERTH
thanks, occasionally i step out of the 1970's!
#5 Posted : Wednesday, 21 July 2010 9:32:53 AM(UTC)
hmmm, think i gotta step out of them as well sometimes
"To remove donuts from wanting to own and drive HO's, God made Monaro's."
Guest (5)
