vphunni Offline
#1 Posted : Wednesday, 21 July 2010 8:10:28 PM(UTC)
vphunni
Hey all,
Lately when starting my car (vr) it makes a metally grinding noise. A friend had a look at it and said it sounded like it was coming from the starter motor. Any ideas what is wrong with it? It makes this sound every time its started.
BIGCAV Offline
#2 Posted : Wednesday, 21 July 2010 8:19:48 PM(UTC)
BIGCAV
is it very loud?
vphunni Offline
#3 Posted : Wednesday, 21 July 2010 8:27:53 PM(UTC)
vphunni
yeah it's pretty loud. It stops once the car is starter. It makes the noise only when it is being started.
BIGCAV Offline
#4 Posted : Wednesday, 21 July 2010 9:58:25 PM(UTC)
BIGCAV
I hope its not for your sake but may be the ring gear on the flywheel worn out, the starter motor gears not engauging properelly and grinding
id pull out the starter motor and check both gear flywheel and starter motors gears for wear
#5 Posted : Friday, 23 July 2010 2:07:21 AM(UTC)
If you have a Delco starter motor on it the front bearing dies in the starter motor and you ar in for an $800ish bill for the starter motor alone if your ring gear is still OK.
If you have a Bosch starter motor their prices are a lot more reasonable.
Vandals and graffiti "artists" do everyone a favour and target parking meters and fixed speed cameras only.
bullitljv8 Offline
#6 Posted : Monday, 26 July 2010 8:45:40 AM(UTC)
bullitljv8
100% its your ring gear i just fixed the same problem on a vn
playwme Offline
#7 Posted : Monday, 26 July 2010 7:26:57 PM(UTC)
playwme
Don't scare her. It's a VR. There is no rational reason on earth to pay $800 for any single part on that car. Any more than $50 for a used starter motor and you're getting ripped hard.
bullitljv8 Offline
#8 Posted : Monday, 26 July 2010 8:52:01 PM(UTC)
bullitljv8
you mean any more than $50 for the whole car dont you lol but yeah starter $50 ring gear $75 then pay someone to put it in should be about $250 so yeah $800 is bulls***
