krustee Offline
#1 Posted : Saturday, 7 August 2010 12:38:49 AM(UTC)
krustee
hi, new to the forum, can anyone please giv some ideas on y my crewman all of a sudden decided it only wants to go on three cylinders. a mechanic has shuffled the coils around and replaced the plugs all to no avail. he has also tried another computer after telling me that vz v6s are prone to s***ting computers, no one else has backed this claim, any ideas will be greatly appreciated, thnx
#2 Posted : Saturday, 7 August 2010 1:11:55 AM(UTC)
Hi krustee.
VZ V6 engine computers are generally not prone to sh**ting themselves.
Many mechanics who can't diagnose electrical problems often try to repair cars by 'throwing' parts at the problem at your expense. I find that it's best to find out what the problem is before spending big $$$ on parts that aren't necessary & don't fix the issue.
Your problem it probably wiring related. The VZ coil overs each have their own igniter module on board, so each coil requires their own +ve & -ve supply. Because the coils are wired in 2 sets of 3, my guess is that a common earth or +ve supply is missing. Get somebody who knows how to measures voltages etc. to have a good look. If you have access to a factory circuit diagram, it's even easier. Could be a loose earth bolt !!
krustee Offline
#3 Posted : Saturday, 7 August 2010 5:19:20 AM(UTC)
krustee
Thanks for the info. I have also been advised that it may be fuel related due to bad E10 fuel. Do you have an actual workshop and are you able to look at the problem. I live at Parkes but the car is in Sydney at the moment. My phone number is 0417 231018 or my email is [email protected]. I can be contacted until 3.00am. Thanks, Joe.
Originally posted by Dr Terry
Hi krustee.
#4 Posted : Saturday, 7 August 2010 8:04:58 AM(UTC)
Hi krustee.
You have mail.
Regards Dr Terry.
lildog Offline
#5 Posted : Saturday, 7 August 2010 8:06:34 AM(UTC)
lildog
Check the fuses in the under bonett fuse box, there is a fuse for odd and even cylinders.
krustee Offline
#6 Posted : Monday, 9 August 2010 9:22:01 AM(UTC)
krustee
thanks guys for the input, im assuming it was fuel related as the prob has cleared up after a couple of hot laps round the block, been advised from a number of people to give up the e10 and only drink ulp or premium
Guest (5)
