Anthony333 Offline
#1 Posted : Tuesday, 7 September 2010 7:09:04 AM(UTC)
Anthony333
Hi there,
I am installing a small block Chev in my HT and need some advice on a box ;-),(Just a mild 307 )i think turbo 350 will be good for me... but, what crossmember, tailshaft, diff ? Thinking VL Diff.... not sure, just poking about for other possible options ? M21 ? Glide ? Cant afford Saginaw ..hehe
Thanks for any advice people :-)
#2 Posted : Tuesday, 7 September 2010 7:38:23 AM(UTC)
Might be worth considering whacking in a powerglide so its all stock and easy , i can help you with many of the bits you need. Box , tailshaft , crossmember etc..
www.monaromuscleparts.com
#3 Posted : Tuesday, 7 September 2010 7:46:23 AM(UTC)
I agree with James, but TH350 is just as easy. It'll fit wherever a Powerglide fits tailshaft, crossmember wise etc. Just needs a HT-HG trimatic T-bar to operate it. Brand new Muncies are relatively cheap too, and will fit if the HT originally had a Saginaw in it.
Note, VL diff is slightly narrower, VN-VSIII is slightly wider and easier to get.
Anthony333 Offline
#4 Posted : Tuesday, 7 September 2010 8:04:42 AM(UTC)
Anthony333
James, PM sent....
How much HK HT HG stuff do you have ?
I have 2 projects, so might need all sorts of things :-)
Cheers, Ant
Premier 350 Offline
#5 Posted : Wednesday, 8 September 2010 11:48:38 PM(UTC)
Premier 350
Wot about an overdrive auto? Would a TH 700 go in? Make for more relaxed highway driving.
Of course I could rave on about gelati..........i
One pair of hands working does more than a thousand pairs praying.
#6 Posted : Thursday, 9 September 2010 3:02:06 AM(UTC)
Not without floor crossmember mods.
Anthony333 Offline
#7 Posted : Friday, 24 September 2010 3:47:06 AM(UTC)
Anthony333
Thanks for the advice... just bought a TH 350 , only need a crossmember now..any recommendations ?
#8 Posted : Friday, 24 September 2010 5:12:22 AM(UTC)
Standard HT-HG V8 Powerglide crossmember or Saginaw crossmember will do, If it's a short TH350 (same length as Powerglide).
adam PERTH Offline
#9 Posted : Friday, 24 September 2010 5:26:15 AM(UTC)
adam PERTH
TH350 crossmember locating point on crossmember shorter than powerglide by about 2 inches.
i think CRS do them off the shelf...
Tuning for Holley carbs in Perth? PM me.
Edited by user Friday, 24 September 2010 5:27:27 AM(UTC)  | Reason: Not specified
#10 Posted : Friday, 24 September 2010 5:42:34 AM(UTC)
Adam, you are mistaken. They are the same. See attached link. The only different Powerglide I have ever seen is the Holden 6cyl one.
http://www.maliburacing.com/auto_tranny_id.htm
adam PERTH Offline
#11 Posted : Friday, 24 September 2010 7:12:08 AM(UTC)
adam PERTH
not too sure about those measurements.
the T350C also comes as non cable kickdown - they have it listed as cable kick only.
they also list the glide as a different overall length to the T350 6" ext housing length, but yet they run the same tailshaft.
if T350 was same as powerglide, then why is the powerglide and T350 crossmember points different for HQ-WB?.
Edited by user Friday, 24 September 2010 7:16:00 AM(UTC)  | Reason: Not specified
#12 Posted : Friday, 24 September 2010 4:23:13 PM(UTC)
Not sure about the cable kickdown. Never seen one without.
That overall length is a bit strange. However the mount data is right as far as I know. The idea was that the smaller boxes all fit in the same spot ie Powerglide, Saginaw, TH350, TH200. Same as the TH400 and the TH200-R4 use the same mounts to each other. I know the TH700R4 uses alomost the same mount as a TH350 (as cam be seen in that link data), and i'm almost certain the same goes for a V8 powerglide crossmember and a TH700R4. I'll look at some in the shed this weekend. Got me thinking now...
Guest (10)
