hkute68 Offline
#1 Posted : Tuesday, 14 September 2010 7:06:14 AM(UTC)
hkute68
hey gurus
i am getting my diff rebuilt and when i get it back am going to repaint it.what colour was it originally ?,3.55 single spinner banjo.
hazzard county Offline
#2 Posted : Wednesday, 15 September 2010 6:50:09 AM(UTC)
hazzard county
I'LL TAKE A STAB AT IT AND SAY BLACK
hkute68 Offline
#3 Posted : Wednesday, 15 September 2010 7:14:07 AM(UTC)
hkute68
i asked this question because inside there is a colour similar to the top of the steering box,would it have been be the same on the outside of the diff?.
Ayios Offline
#4 Posted : Wednesday, 15 September 2010 9:34:49 AM(UTC)
Ayios
every diff on the outside i have ever seen has been black..
The inside of the diff I have seen that orangy colour.
______________________________________
Speed has never killed anyone, suddenly becoming stationary... thats what gets you
abi Offline
#5 Posted : Thursday, 16 September 2010 6:33:09 AM(UTC)
abi
Hi hkute68,
I recall the diff centres are painted on the inside from the OEM supplier so as to lower the warranty rate on diff bearing noise.
If not coated, the 'as cast' surfaces and freshly machined surfaces release into the oil fine iron dust and graphite, this is because the centres are cast iron.
Normally the ring and pinion are OK with fine iron dust but the bearings hate it!
Hope this answers the Q.
hkute68 Offline
#6 Posted : Friday, 17 September 2010 4:36:08 AM(UTC)
hkute68
ok thank you very much for that info ,that clears things up for me.
Mike81973 Offline
#7 Posted : Monday, 20 September 2010 8:27:47 AM(UTC)
Mike81973
Hi,
not sure about HK's but I can tell you that my Torana had a colour splotch on the rear which matches the body colour, this splotch is also on the gearbox.
Many Holden had a charcoal coloured firewalls but you can have some very heated aguments about this, and before ou ask no they don't all fade to charcoal in an perfectly even manner.
It might be possible that diffs are painted the same colour as the underbodies and many had charcoal under bodies, not black!
black is the colour that colour blind painers or ones that don't care paint their firewalls and underbodies.
An exception to the charcoal coloured firewall is the XU-1 which had the gey charcoal colour overpainted black from new, but the boots were still charcoal!
Mike
Purpul Police
Purpul Police
