#1 Posted : Tuesday, 18 May 2004 12:40:20 AM(UTC)
Want to do the conversion from red 202 to Gen III in 78 HZ Station Wagon with full emissions, any info would help. Daniel
#2 Posted : Tuesday, 18 May 2004 1:13:03 AM(UTC)
Daniel,
With all due respect.
If this is ur fist conversion job, u should keep it simple and just install a Holden 308 EFI.
easy no brainer (not to say u dont have any brains tho.) with guaranteed results.
buy a commodore donr and
#3 Posted : Tuesday, 18 May 2004 1:20:22 AM(UTC)
Have you tried Pat Gardiner conversions in Moree NSW, he has a website, and may make a kit to suit this conversion??
Peter
#4 Posted : Tuesday, 18 May 2004 1:57:16 AM(UTC)
Sounds like you are going to have to do a gearbox conversion as well..
So you can also include crossmember, tailshaft, gearbox shifter, gearbox control depending on type (ie auto elec, auto hyd), possible tunnel modifications (dunno if 6 tunnel is diff f
#5 Posted : Tuesday, 18 May 2004 2:13:40 AM(UTC)
Castle auto electrics (03 5472 1442) make a kit for it, but its pretty expensive. you need a custom sump and pickup, the LS1 sump has all sorts of weird things in it so its hard to make (but you can buy them). you need all the engine & trans mounts et
#6 Posted : Tuesday, 18 May 2004 6:45:03 PM(UTC)
Am i mistaken to think the Holden EFI heads will outflow any of the Chev heads as well?
with money saved in the conversion using a Holden 308, U can build up a stroker bottom end, and have a Chev muncher.
no malice intended toward Chevs, but I
#7 Posted : Tuesday, 18 May 2004 8:55:49 PM(UTC)
Standard VN heads are going to flow better than the old standard Chev heads. (they are years and years newer!). I dont know about the Fuellies though. In terms of aftermarket, i think overall chev flows better than holden.
2 things....a standard
#8 Posted : Tuesday, 18 May 2004 10:38:21 PM(UTC)
Ed, no offence taken from you comment but this is a 2-3 year project. So cost and time aren't really a factor. Would probably put a toughened th400 behind it and a9 inch down the arse. Tickle it with nitrous and go from there. Looked at capa blowers butn
#9 Posted : Wednesday, 16 February 2005 7:17:31 PM(UTC)
