#1 Posted : Saturday, 4 February 2006 3:52:35 PM(UTC)
HZ 253 V8 pollution manifold.
There is a valve of some sort that is on the LH side of the inlet manifold, running beside the LH rocker cover that has a vacume line running to it from a sender in the front of the inlet manifold, it then has a rubber vac hose that loops on the back of the unit with a one way valve?? It has a large flat 2xtermional plug with pink wire running to and from it. I traced the wires and they look like they run to the kick down switch but there is a pink wire that is loose that possible went to an elec sender on the front of the eng somewhere, it has a single female spade terminal??
In short, can I remove this whole unit assy and will it effect the running of the car. I don't think it works as there is that one wire that is not connected to the front of the eng somewhere?
What is it, what is it sposed to do?
Darren
308hjute Offline
#2 Posted : Saturday, 4 February 2006 5:58:00 PM(UTC)
308hjute
Darren,
Sounds like the vacuum switch for your distributor's vacuum advance. They were setup so that the vacuum advance only worked when the engine was above a certain operating temp and the transmission was in top gear (I believe). The switch at the
#3 Posted : Sunday, 5 February 2006 12:05:56 AM(UTC)
Thatnks for that Kev,
I do have a direct vacuum line to the dissy from the carb. If you could get me the dia somehow that would be great. I seemed strange that the vacuum line would be looped back onto it's own tee join at the back of the unit, it serve
CherryBomb Offline
#4 Posted : Sunday, 5 February 2006 5:02:31 AM(UTC)
CherryBomb
For legal reasons I wouldn't remove the Canister. Regardless that it no longer serves its intended purpose, The Law will ASUME that it dose! Stupid as it really is.
I would block the small hoses to the carb (from the inside) and let life go on :)
If
Never stop being inspired,
#5 Posted : Sunday, 5 February 2006 4:21:22 PM(UTC)
Yeh...thanks Dan, I know what youre saying. It's a bit stupid though, if it don't work, you can buy, why waist time having it there?
308hjute Offline
#6 Posted : Monday, 6 February 2006 1:36:51 AM(UTC)
308hjute
Darren,
I have scanned the relevant pages from my Gregory's.
http://i47.photobucket.c...f172/308hjute/emission/
Hope this helps.
Kev
Edited by user Monday, 6 February 2006 1:38:01 AM(UTC)  | Reason: Not specified
#7 Posted : Monday, 6 February 2006 4:38:31 PM(UTC)
Kev
Thank you sooo much for doing that for me, it helps me greatly.
Darren
308hjute Offline
#8 Posted : Tuesday, 7 February 2006 7:03:57 AM(UTC)
308hjute
Too easy,
That's the idea behind Fastlane's message boards I think. Help each other out when we can.
Kev
#9 Posted : Tuesday, 7 February 2006 8:46:23 AM(UTC)
Yeh, it's good to share what we do....I took the vacuum valve off and it looks a lot neater and still runs, which is a plus!
I got failed on rego today for lower ball joints....any tricks to changing these as I don't have a press handy. A guy told me to
#10 Posted : Tuesday, 7 February 2006 9:31:51 AM(UTC)
Definately freeze the new ones - I like to put them in overnight, and remove them right when you are ready to install them.
Don't hit the frozen ones with a hammer though, as they crack real easy!
_____________________________________
#11 Posted : Wednesday, 8 February 2006 12:49:51 AM(UTC)
Thanks guys.
I took the lower arms out and got a local workshop to press out the old joints....I must have one of the few that are still tight, wouldn't budge with a hammer so while I was there they pressed in the new one and ask why were the new ones so
This page was generated in 0.091 seconds.
