Mr.Jones Offline
#1 Posted : Friday, 26 November 2010 2:47:10 AM(UTC)
Mr.Jones
LX sports sedan on AMCS http://australianmusclec...les.com.au/muscle/145748 check out the body plate the ultimate nasco accessory.
Leroy
Voltaire
Voltaire
#2 Posted : Friday, 26 November 2010 4:10:22 AM(UTC)
wow, that's a cool car!!
iv'e never seen nasco stamped on a body plate, was this standard on nasco body's?
dirty davo Offline
#3 Posted : Friday, 26 November 2010 7:45:51 AM(UTC)
dirty davo
Leroy
interesting body plate
that means it was a "nasco replacement body shell"
most of the time the repairer discarded this one & put the original one in its place
regards dirty davo
Voltaire
git Offline
#4 Posted : Friday, 26 November 2010 5:37:00 PM(UTC)
git
Greetings, This is a very interesting point when you consider that the NASCO name had been replaced by GMP&A by this time. Even the dealer supplied information was now GMP&A News and not NASCO News as it once was known. Perhaps this was a way of identification of the regular replacement body shells as opposed to the all-mighty GMP&A A9X body shells?
look out, the guru is coming through...
#5 Posted : Friday, 26 November 2010 5:48:24 PM(UTC)
I was going to mention the same thing. GM-H last used the name NASCO in 1974, when it was officially changed to GM P&A (General Motors Parts & Accessories).
You would have to ask how the NASCO name got onto a body plate that also had '77 Style' stamped on it. This dates it as 1976 or later.
As git has said it's probably not one of the A9X type race shells, it may well be just a regular replacement part shell & it used up an old stock NASCO ID plate.
Mr.Jones Offline
#6 Posted : Friday, 26 November 2010 7:32:47 PM(UTC)
Mr.Jones
Looks like the Nasco name survived into the 80's http://gallery.oldholden...placement+shell.JPG.html
The model no. on this is interesting WB8W80
Leroy
Voltaire
Voltaire
