threespeed Offline
#1 Posted : Saturday, 27 November 2010 10:40:12 PM(UTC)
threespeed
I am trying to find out what model holden do head Part No. 9936122 are off.
They came off a 308 engine No. prefix QT cast date 77, the heads have cast date's 20 D 7 & 24 S 7. The information that I have read indicates that they are off a VB model but the cast date of 77 seems a bit early for a VB.
Appreciate if someone could advise what model holden do the heads come off HX, HZ or VB?
Edited by user Sunday, 28 November 2010 8:56:53 PM(UTC)  | Reason: Not specified
#2 Posted : Sunday, 28 November 2010 3:08:40 AM(UTC)
Casting number 9936122 are ADR27A heads off an 4.2 or 5.0 V8 as used in LX (7/76 onwards), HX, HZ & VB. They can be identified by their U-shaped EGR port.
threespeed Offline
#3 Posted : Sunday, 28 November 2010 3:43:14 AM(UTC)
threespeed
Thanks for the reply Dr Terry.
I was a litle confused when I read the book "How to build a Hotrod Holden V8" the cylinder head Part No listed casting No. 9936122 as fitted to the holden VB model, obviously a misprint.
#4 Posted : Sunday, 28 November 2010 4:13:44 AM(UTC)
As Dr Terry says they are VB heads.
#5 Posted : Sunday, 28 November 2010 7:04:04 PM(UTC)
actually Dr Terry states 76 onward including VB which was late 78.
#6 Posted : Sunday, 28 November 2010 7:12:47 PM(UTC)
Head dates dont make sense....24"s"7....the heads dont match and arent from the same engine
unless somethings a misprint.obviously it is.
threespeed Offline
#7 Posted : Sunday, 28 November 2010 8:18:51 PM(UTC)
threespeed
Re-checked the head date codes and 24 S 7 is actually 24 E 7. would this make the heads of a HX Model?
Edited by user Sunday, 28 November 2010 8:25:05 PM(UTC)  | Reason: Not specified
#8 Posted : Sunday, 28 November 2010 9:32:36 PM(UTC)
Id go HX
#9 Posted : Monday, 29 November 2010 12:02:13 AM(UTC)
Yes, which means he said they are VB heads and the info threespeed quotes is not a misprint as stated.
24E7 will be HX or LX, or possibly very early HZ (but unlikely).
#10 Posted : Monday, 29 November 2010 12:15:12 AM(UTC)
vb commodore was released in officially October '78 these heads are early '77 I still think HX
#11 Posted : Monday, 29 November 2010 12:37:06 AM(UTC)
Threespeeds won't be VB, but the casting number is VB.
HX or LX as as above.
#12 Posted : Tuesday, 30 November 2010 8:13:13 AM(UTC)
Casting date says they are not VB they are earlier despite part number so why would you agree with VB with an obvious earlier cast date?
Doesn`t the cast date depict the model year it was fitted to.
#13 Posted : Tuesday, 30 November 2010 4:16:43 PM(UTC)
Easy, because ALL red ADR27A heads are identical.
This page was generated in 0.095 seconds.
