RJR Offline
#1 Posted : Sunday, 5 December 2010 1:34:50 AM(UTC)
RJR
needs some advise on what's the best carb set up to use on my modified black 3.3, at the moment I have the varajet with probably not the right manifold and a redline freeflow which I'd like to keep on it, and some how needs a set up to warm the system up cold start as it keep stalling on me till it gets up to temperture, then after that no problem, but it is dame thirsty on fuel when I've only got the original fuel tank.
your help would be appreciated and diagrams or photo's if possable
the motor is set up in my FJ
#2 Posted : Sunday, 5 December 2010 3:00:23 AM(UTC)
how about trying a 34 ADM weber carby, they are found on the XE/XF fords there great carbys, a simple adapter plate and it will fit straight onto the varajet manifold
the varajet carbs are crap, the weber will be much better IMHO
if you decide to go for the weber and need a adapter then i make them and i can make you 1
i'm not suggesting the weber just to sell you a adapter, i make adapters to fit any carby to any manifold and i'm not fussed where you get your adapter from if you need 1
everyone i know that has fitted a 34 ADM weber to the red 6 is very happy with the results
another option would be a 2 barrel stromy, i prefer the webers though, the strombergs need to be jetted right to suit your motor
#3 Posted : Sunday, 5 December 2010 3:26:41 AM(UTC)
I agree with Dave I had a weber on a 225 lots of years ago and it flew,way better than factory 3.3 carbs.
petaus Offline
#4 Posted : Tuesday, 7 December 2010 6:33:04 AM(UTC)
petaus
the varijet is just a mini quadrajet, it,s a good carb when working well not good when many fingers have been in there.
pete.
RJR Offline
#5 Posted : Friday, 10 December 2010 4:56:32 AM(UTC)
RJR
thanks davequey74, have decided on the 34 ADM Weber carb,
when rebuilding the motor I did away with the exhaust manifold and fitted a freeflow, any suggestions on ways to heat up the carb
#6 Posted : Friday, 10 December 2010 7:29:42 AM(UTC)
no worries mate, did you have any prob finding a adapter and carby in en-zed
RJR Offline
#7 Posted : Saturday, 11 December 2010 12:50:58 PM(UTC)
RJR
will find out middle of next week redline supposeable has them, if not right will let you know, whats your email address if the one I get is no good. cheers
#8 Posted : Sunday, 12 December 2010 3:01:07 AM(UTC)
if you get stuck i can send you 1, email quey74AToldholdenDOTcom
i've never sent anything over the ditch before but it shouldn't cost to much??
