#1 Posted : Sunday, 5 December 2010 3:50:30 AM(UTC)
Is this a HK GTS Monaro motor? (307)with a 327 engine number
? WIERD.
http://cgi.ebay.com.au/3...3362f92995#ht_907wt_1139
#2 Posted : Sunday, 5 December 2010 6:08:49 PM(UTC)
looking at the firewall with the heater box it looks like its in a chev impala/belair /pontiac with HQ brake booster. Its only stroked to a 327 the block is 307. Maybe he has restamped the block or the engine # should have started with 307 questions need to be asked to this seller.
Edited by user Sunday, 5 December 2010 6:14:21 PM(UTC)  | Reason: Not specified
#3 Posted : Sunday, 5 December 2010 6:20:29 PM(UTC)
I have sent him a querie on the #
#4 Posted : Sunday, 5 December 2010 6:57:22 PM(UTC)
307 & 327 share the same 3.25-inch stroke, only the bore changes. The 307 has a 3.875-inch bore while the 327 is 4-inch.
Dr Terry.
antoni Offline
#5 Posted : Sunday, 5 December 2010 9:50:06 PM(UTC)
antoni
Hi all
Yes you can bore a 307 to 4.00 in not good.
I would say someone damaged a 327 motor .
just restamped the 307.
PS got 307 out to 4.020
can be done. but how hot will it get.
Tony
#6 Posted : Monday, 6 December 2010 1:31:38 AM(UTC)
I've had 307's running fine at 4" and 4.030". I wouldn't exactly advise it though.
That is a resonably early Melbourne engine number, and cannot be original on that block unless it is a mistake. A photo of the engine number will tell all. Also a comparison between the cast date, McKinnon engine number and the GMH part of the engine number will also see what has happened.
#7 Posted : Monday, 6 December 2010 4:22:20 AM(UTC)
yep,doesn't add up at all.
#8 Posted : Tuesday, 7 December 2010 2:11:05 AM(UTC)
no reply from the seller!
ghg308 Offline
#9 Posted : Tuesday, 7 December 2010 5:16:01 AM(UTC)
ghg308
i got pictures from seller the stamping doesnt look to bad, it ends weird though ends in "K10"?
#10 Posted : Tuesday, 7 December 2010 5:19:13 AM(UTC)
Should be K1017 or something like that. If all the stamping looks OK it is most likely a mistake, and the engine is probably from an early Melbourne built HK 737 GTS. I have seen an original HT GTS350 with a 308M engine number, number was on the log books and the block.
petaus Offline
#11 Posted : Tuesday, 7 December 2010 5:28:09 AM(UTC)
petaus
how were these engine identified at the factory as they arrived, some sort of shipping tag showing engine size or of the casting numbers?
#12 Posted : Tuesday, 7 December 2010 6:25:11 AM(UTC)
casting numbers are generally not changeable,this engine is a 307. bores are only 20th out.
must just be a 350 crank,307 casting,327 engine number.
petaus Offline
#13 Posted : Tuesday, 7 December 2010 6:30:32 AM(UTC)
petaus
anyone ever heard of pistons for that combination? 307 bore / 350 stroke?
#14 Posted : Tuesday, 7 December 2010 6:47:23 AM(UTC)
No, not unless it is a +0.125" bore (ie 4"), then they are standard 350 pistons.
#15 Posted : Tuesday, 7 December 2010 6:50:17 AM(UTC)
Not sure, but they would have been easy to tell apart by the intake manifold and carby (307 was 2BBL, 327 was 4BBL). The 1969 327 and those for the Chevs and Pontiacs were also a US made engine, 307's were Canadian so easy to pick part that way too.
#16 Posted : Tuesday, 7 December 2010 7:27:14 AM(UTC)
it says only 20th out,it has to be crank and rods unless there is
another way I havent heard of?.also the add says"original steel crank"
doubt it.I dont think the "327" equation is correct.
"CAST NUMBER IS 307"
Here's the question then...only 20th out
original steel crank(so has original stroke)
327....dont think so.
Guest (15)
