based on the great topics that have been on building up 186s etc I have put up a post on my engine buildup. i will be running a manual behind the engine.
I am basically trying to get a good revy motor that looks reletivwly stock, is cruisable but at the same time can beat those annoying falcon/commodore (with rear wing types) that always try to race you.
so far my base is 308 turbo pattern block, decked and bored 60 thou (unfortunately) new bearings etc through whole engine rods and crank (standard) tested, matched and reground acl flat top pistons and kit in bottom end crow cams cam (5616 is the model) vn heads with oversize values and hardened springs redline manifold to suit new timing gear, harmonic balancer etc barry grant 750 demon carby holley blue fuel pump msd ignition, coil and dizzy etc new starter motor high volume oil pump pacemaker extractors
i was planning on high volume sump electric water pump new alternator roller rockers (do i need molley rods)
if anyone has any comments, things i could improve or ideas as to how good or bad this setup will be that would be great. =)
ashley
sounds like a nice strong 308, will go nice at these specs, should leave most things for dead off the lights
sound good is it already to go? zac
Nothing beats cubic inches !!!
and wot manual gera box? zac
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
Ashley.
Sounds like a strong engine. From years of playing with Holdens, the only piece of advice I would give you is that 'you can't beat cubic inches'. The engine you have posed will be very strong, and sweet. But it most likely will get beaten in a |
Cheers guys.
The engine has been largely built at this stage.
Byron i didnt go for the stroker as I had heard that they can have more reliability issues.
As the car it is going in is mostly for crusing Im not too worried about drag racing. Just w
You've done the right thing for trouble free transmission/diff. I didn't mean you should be building it for drag racing, just using the 1/4 mile as a comparison. If you want to cruise and have good low down power, go slightly conservative on the cam and |
