blameyone Offline
#1 Posted : Tuesday, 15 February 2011 10:10:46 AM(UTC)
blameyone
Just curious to know. I've been cleaning up a salisbury diff out of a HK monaro and noticed the writing cast in the middle at the wheel end. Written what looks like HOLDEN & D68 on one and the other what looks like HOLDEN & DH3587, any clues to what it means.?....Jack
blameyone Offline
#2 Posted : Wednesday, 16 February 2011 10:25:42 AM(UTC)
blameyone
I always thought that too, a left and a right. Part # 2808843 is listed in the HK, HT and HG parts catalogues as the salisbury rear axle and 2 for each vehicle, no left or right. But in the 327 supplement to the original HK catalogue the part # 7437374 is listed as the part # for the 327. axles What is the difference in these axles ?
69 rust bucket Offline
#3 Posted : Wednesday, 16 February 2011 7:15:54 PM(UTC)
69 rust bucket
being hk the diff is a clutch type and ht hg has a cone type centre this would be the variation in part number i'd say not 100%. but the chap that rebuilt my 10 bolt at the time i asked him to leave the axles out so i could redo my brakes.he marked 1 left 1 right.so the plot thickens sorry
Edited by user Wednesday, 16 February 2011 7:18:04 PM(UTC)  | Reason: Not specified
why drink & drive when you can drift & slide
blameyone Offline
#4 Posted : Thursday, 17 February 2011 11:11:44 AM(UTC)
blameyone
Someone on here must know, but as you say the plot thickens. I sort of hope there is a left and right because listen to this. Somewhere in the mid 1970s I broke an axle in a HK 307 auto salisbury diff premier and I was with a lady friend a long way from home, middle of winter and middle of the night , I spent a day waiting for the local wrecker to get me a replacement axle he said he only had one to suit the other side and would take a day to get me one which he eventually did. Now if there is left and right thats fine ,but if left and right are the same he did have an axle to suit the premier, well that would be very disappointing. because after I spent all that time getting that axle back in I was now running very late for the girl and I to get to a good mates wedding, well we did'nt get to the wedding for in the mad rush to get there I rolled the car, total wreck. No it has'nt finished yet. I had only bought the car in the last week and the car salesman who sold me the car did'nt fill out properly the cover note for the insurance when I bought the car. No it has'nt finished yet. despite all efforts to get his company to cover the loss, no way. So that beautiful wrecked car sat in the driveway for the next 2 years till I had it paid off. All for a broken axle.....so maybe now I'm not real sure if I really want to know if there is a left and right or not. One way or another these are the experiences that make life so interesting.....Jack
castellan Offline
#5 Posted : Friday, 18 February 2011 7:22:36 AM(UTC)
castellan
I recon it's bull.
And the 307 auto HK premier had a banjo diff 2.78 ratio.
Only the ford 9 inch has short & long axles
castellan Offline
#6 Posted : Friday, 18 February 2011 7:26:57 AM(UTC)
castellan
They maybe on about the 12 bolt HK HT Monaro diff with the low ratio's
#7 Posted : Friday, 18 February 2011 4:51:34 PM(UTC)
Not quite true. AFIAK all B/W rear ends fitted to Falcons, Valiants & late VK onwards Commodores also have long & short rear shafts.
You may ask why use 2 different lengths ? It is quite obvious when you look closely. Because the diff centre has the crown wheel to one side, with equal length axles it places the tailshaft off-centre. With unequal axles it places the tailshaft dead centre. Many do not believe this, but take a look under any old Holden (from 1948 up to VK Commodore) & you will find both the tailshaft & tunnel are off-centre.
P.S. The ultra-rare 12-bolt HK/T/G rear axles have 30-splines instead of the regular 28.
Edited by user Friday, 18 February 2011 4:53:30 PM(UTC)  | Reason: Not specified
#8 Posted : Friday, 18 February 2011 4:58:49 PM(UTC)
I recon it's bull.
As standard, but it also had a 186 3spd as standard fitment. Like the 307 engine the HK Prem was optionable with Salisbury rear axle.
blameyone Offline
#9 Posted : Friday, 18 February 2011 11:55:14 PM(UTC)
blameyone
I've just found, The axles, according to Allan Colvins' "chevrolet by the numbers" publication, 10 bolt L and R diff axle shafts are the same length. There are many different lengths Salisbury axle shafts but for each application L and R are same. ...HK1837 Did'nt the 307 premiers with auto came with 10 bolt as standard ?....Jack
#10 Posted : Saturday, 19 February 2011 2:01:18 AM(UTC)
They may have, although I thought 2.78 banjo was standard and 3.08 or 3.36 Salisbury were optional. Either way you could get a Salisbury. 186 was standard and 307 could be optioned on HK Premier, therefore any diff other than 6cyl banjo is an option, regardless of whether it was standard with 307 or not. I think that prior to Monaro release all 307 HK were 2.78 LSD banjo anyway.
Edited by user Saturday, 19 February 2011 2:02:00 AM(UTC)  | Reason: Not specified
Squeak327 Offline
#11 Posted : Saturday, 19 February 2011 5:28:13 AM(UTC)
Squeak327
Jack I have had the axles out of my HK salisbury (early Eaton type with clutch pack LSD mechanism) and can confirm that they are both the same length.
However, it may interest you to know that when I discussed diff rebuilding with a long established and reputable diff rebuilder locally, he told me that it is important to ensure that the axles are returned to their original sides. He said that this is because over time, torque force applied on the splines of each axle in normal use puts the minutest twist in the splines. This is very rarely visible to the naked eye but apparently is visible under X-ray. He explained to me that if you put used axles on the 'incorrect' side the torque force will then be opposite to what that axle has experienced over its years of service. Because the steel in these axles 'crystalises' with age (resulting in reduced strength), putting rotational stress on the axle in the 'wrong' direction can often lead to breakage. Because the axles are almost impossible to find, you will then be up for billet replacements.
blameyone Offline
#12 Posted : Saturday, 19 February 2011 7:17:10 AM(UTC)
blameyone
Thanks Squeak327. Yes, as it happens I was speaking to bloke at southern differentials this arvo and he expressed a similiar caution about switching sides with the axles. What this really means is there is no left and right but there is axles that have been used on the left and others that have been used on the right and should continue to be used as such....all the best regards ...Jack
blameyone Offline
#13 Posted : Saturday, 19 February 2011 7:25:50 AM(UTC)
blameyone
Back again, seems axles aint axles. Still have'nt found what all the numbers and letters are cast into the axles. Is there a possibility they are date cast numbers? and what of the two different part #s....Jack
git Offline
#14 Posted : Wednesday, 23 February 2011 5:52:59 PM(UTC)
git
Greetings, I think you will find that the reason for the different part numbers is because HT had a thicker wheel flange and longer wheel studs as part of the upgrade from HK to HT. The wheel bearings also changed at this time. The cast numbers/codes are for production batch identification purposes as the axle shafs for these imported rear ends were cast at Holden.
Very nice reasoning on why an axle should only ever turn in one direction by Squeak327.
look out, the guru is coming through...
blameyone Offline
#15 Posted : Wednesday, 23 February 2011 9:49:18 PM(UTC)
blameyone
Hi git, that may be the case but that does not add up because the change was in the HK books well before the HT arrived.... Jack
#16 Posted : Thursday, 24 February 2011 1:22:01 AM(UTC)
74xxxxx is a HK part number and 28xxxxx is a HT/G part number. What is in the parts catalogues is not a record of what was fitted to vehicles, but a means for 2nd hand vehicles to be serviced by GMH dealers at a later date. Obviously something changed with the HT/G axles (git answered that for you if the info is correct, I have no knowledge of this) and then these became spares for HK as well as HT/G. I'll bet you got the 28xxxxx number for HK from the blue 1972 catalogue?
#17 Posted : Thursday, 24 February 2011 2:36:59 AM(UTC)
It would be the length of the axle stud would make the part number different at a guess . IF they came with studs , as HK studs are shorter than HT HG .
#18 Posted : Thursday, 24 February 2011 3:51:10 AM(UTC)
...Jack
I think that it is more than likely that the HK/T/G axles were Australian made. They are uniquely Holden, because they have an unusually large flange offset to suit the Holden rear brakes & the Holden rear bearing. Neither of these are items are seen on any GM US vehicle. The stud pattern is also uniquely Holden.
#19 Posted : Thursday, 24 February 2011 4:18:41 AM(UTC)
Nice Dr Terry,Australian made by who?
#20 Posted : Thursday, 24 February 2011 7:17:56 AM(UTC)
GMH also "made" the housings from what I have heard lately.
This page was generated in 0.104 seconds.
