#1 Posted : Monday, 7 March 2011 8:54:58 AM(UTC)
Hi there
Can someone tell me what model these centre caps are off??
Does someone do repo versions??
Bruvpig Offline
#2 Posted : Monday, 7 March 2011 8:28:11 PM(UTC)
Bruvpig
Jeremy, they look like the centers out of the Monaro hubcap
Stepping stone or stumbling block...your choice
BIGCAV Offline
#3 Posted : Monday, 7 March 2011 8:31:40 PM(UTC)
BIGCAV
im no expert but they look like LC LJ covers to me
http://www.rarespares.ne...c&pno=0&description=wc10
or as bruvpig said, modified from a monaro cap
Bruvpig Offline
#4 Posted : Monday, 7 March 2011 8:59:42 PM(UTC)
Bruvpig
yep that looks like them allright
#5 Posted : Monday, 7 March 2011 11:44:54 PM(UTC)
Mystery solved
Thanks gents
adam PERTH Offline
#6 Posted : Monday, 14 March 2011 12:12:33 PM(UTC)
adam PERTH
LC GTR and XU-1
blameyone Offline
#7 Posted : Tuesday, 15 March 2011 6:34:46 AM(UTC)
blameyone
Jeremy, the ones pictured are to suit an LC- LJ GTR. They are separate from the wheel and are held on by the five purpose made nuts. They are very close to the HK-T-G sports disc centre which is spot welded to the rest of the disc.....Jack
#8 Posted : Tuesday, 15 March 2011 6:39:50 AM(UTC)
The monaro hubcap I have in my hands has the cetre bit held in with 5 philips head screws. Has it been modified? I want to sell it so if it has been stuffed about with it would be handy to know.
adam PERTH Offline
#9 Posted : Tuesday, 15 March 2011 9:01:47 AM(UTC)
adam PERTH
LJ GTR / XU-1 are different, they are painted black in the middle, not red like LC.
#10 Posted : Tuesday, 15 March 2011 9:41:35 AM(UTC)
Thanks everyone
when did the LC stop production and switch to LJ??
#11 Posted : Tuesday, 15 March 2011 6:08:46 PM(UTC)
Originally posted by jpb308
Thanks everyone
The LJ was officially released in early Feb 1972. As the factory shuts down for a short period over Christmas & they would need a few weeks to stockpile cars for release, the last LC was most likely built Dec 1971.
#12 Posted : Tuesday, 15 March 2011 6:11:09 PM(UTC)
Thanks Terry
Squeak327 Offline
#13 Posted : Tuesday, 15 March 2011 7:49:22 PM(UTC)
Squeak327
Not necessarily - some are fixed with phillips head screws and washer while others are rivetted. Can't tell you whether this was a specific factory thing or whatever but it is a bit like the different lion emblems in the centre cap - look around and you will see a number of slight variations in the Lion itself.
#14 Posted : Tuesday, 15 March 2011 9:44:41 PM(UTC)
The centre cap is spot wleded to the outer on Monaro hub caps.
The fake nuts are held on by philip's heads crews on HK and rivet on HT/G.
The different lion emblem is ue to damage to the die, there are about 6 different ones and all are avaialable on Hk to HG.
Warren
Squeak327 Offline
#15 Posted : Tuesday, 15 March 2011 11:52:36 PM(UTC)
Squeak327
Well there you go I have learned something again today.
Thanks Warren
blameyone Offline
#16 Posted : Thursday, 21 April 2011 3:58:17 AM(UTC)
blameyone
Thanks Warren, thats what I was trying to say above re Monaro sports discs and Torana centre caps. As you've said they are definitely spot welded on despite what appears to be a simple matter of unscrewing some philips head screws or drilling out some pop rivets. AND separating the centre cap from the outer is not an easy matter as the material is very thin . The torana centre caps are a separate item altogether and not fixed and are held in place only by the wheel nuts each time you fit the wheel. You may find the torana centre cap is a heavier material made of stainless steel. The monaro sports discs are also made of stainless although the centre cap is much more susceptible to rusting, maybe a lesser quality of steel. A side by side comparison of the two centre caps they look very much the same other than the very obvious cut out for the nuts on the Torana ones. If you're keen with a bit of work the Torana ones could be used on the monaro sports disc. The false nuts may just cover the cut out for the nuts.....Jack
dirty davo Offline
#17 Posted : Friday, 22 April 2011 6:03:15 AM(UTC)
dirty davo
[quote]Originally posted by Warren Turnbull
Warren
[/quote
sumwhere i have pics of 8 or possibly 9 diferent versions of lion on centrecaps & yes thats due to damaged dies b4 they repaired & reused dies again.(nb on all gtr ones, (wit cut outs for nuts), lion appear to be all the same as eachother,
when i used to have these restored, cuppla yrs ago, i tried to find sets of 4 that would pass as matching ones.( centre caps are mild steel & chrome plated. nuts & rest of outer is stainless)
seems to me that even a set of 4 original ones off a 1 owner car varied an not exactly th same. oviously if you replaced 1 or 2 at any stage they varied slightly or significantly
th one thats pictured is th latest version that was never on any hk original ever, but was mostly all HG & all GTR (same as what they repro'd, with the full double tailed fish in middle
thats my theory anyway & by no means gosspel
regards DD
dirty davo Offline
#18 Posted : Friday, 22 April 2011 6:19:03 AM(UTC)
dirty davo
Hi there
those look quite good on the chev rally rims pictured here!! (almost like they shoulda been there from factory)
all GTS sports wheel disc centre caps, & also GTR centrecaps, were made from th same guage mild steel version & chrome plated)
then for torana they cut the ear off & u shaped it for wheel nut to retain it in place
mite even dig out a set & put on my crusty pightute rims, then sell th original chev centre caps to someone needing th propper chev centrecaps!!
regards DD
The HKTG Garage Offline
#19 Posted : Friday, 22 April 2011 11:17:46 PM(UTC)
The HKTG Garage
Warren
Warren, I have HT sports wheel discs with screw on nuts.
blameyone Offline
#20 Posted : Saturday, 23 April 2011 6:00:28 AM(UTC)
blameyone
Yes that is correct. Please read carefully. THE nuts( they are false nuts, imitation nuts, just pretend nuts) on HK-T-G Sports discs are held on by either phillips head screws or pop rivets. The pop rivets or phillips head screws do NOTHING to hold the centre cap to the main outer disc. To separate the centre cap from the main outer disc you will need to use a spot weld drill or similiar device....Jack
Guest (19)
