panoman Offline
#1 Posted : Sunday, 17 April 2011 9:02:42 PM(UTC)
panoman
I don't like the standard holden type mirrors fitted to my HG Panelvan. However I do like this look, but kinda hard to judge just by a photo.
http://gallery.perryr.com/main.php?g2_itemId=3196
Has anyone put this style of mirror on their HKTG, and do they bolt
up OK, do they sit nice and level, do you like the look and what model mirrors did you use.
275monaro Offline
#2 Posted : Monday, 18 April 2011 7:21:54 PM(UTC)
275monaro
they look like ford xb mirrors i had a set of these on a hj many years ago they looked good but were a pain ti install very hard to get to the nuts . not sure how they would fit and look like on a hktg
Bruvpig Offline
#3 Posted : Monday, 18 April 2011 9:56:49 PM(UTC)
Bruvpig
They are probably the ones that are or were available in the autoparts stores about 20-30 years ago as replacement mirrors. I had some as a kid on a HK, so they do bolt on. But from memory, one of the holes was not needed, and you had to drill another one in the door.
As per 275Monaro's post, they were based on the ford GT or similar mirror of the day, and the ducks guts for a teenager with a hot dog exhaust.
(might even base my pano restoration on the photo!!! Thanks....not)
Brian
Stepping stone or stumbling block...your choice
Bruvpig Offline
#4 Posted : Monday, 18 April 2011 10:04:25 PM(UTC)
Bruvpig
As for a replacement mirror.. if you are going down that route not using original, I like the ford XY gs mirrors or similar models
http://cgi.ebay.com.au/F...ries&hash=item1c1b0d2a00
they still look period, but a little more fancy than the standard mirror, and are a universal fit for left and right.
But everyone has their own taste, and that's what makes it fun.
panoman Offline
#5 Posted : Tuesday, 19 April 2011 2:04:11 AM(UTC)
panoman
I will keep and eye out on ebay, for a cheap or broken XB mirror just to see how it sits on the car. I want the mirror to sit square, not hang down at all and as its not made for the car it probably won't bolt straight on. But as you said thats part of the fun of it all.
cheers Mick
Edited by user Tuesday, 19 April 2011 2:06:26 AM(UTC)  | Reason: Not specified
#6 Posted : Tuesday, 19 April 2011 2:24:17 AM(UTC)
These mirrors came factory-fitted on many 70s Fords:- Escorts, Cortinas, Capris, XA/B/C Falcons etc. etc. They used tapered (wedge) spacers to cater for the shape of the different model's door profiles.
Ford's accessory arm, Motorcraft sold them in kit form with several different wedge spacers to the aftermarket, so they would fit just about anything.
#7 Posted : Tuesday, 19 April 2011 2:30:06 AM(UTC)
I had XB mirrors on a HQ years ago, they came with the car when I got it, I smashed one on a fence post & hade to replace it, thats when I found out you had to file down the base to get a correct angle for mounting, otherwise they looked stupid..
#8 Posted : Tuesday, 19 April 2011 2:45:30 AM(UTC)
74HJLS Offline
#9 Posted : Tuesday, 19 April 2011 4:35:33 AM(UTC)
74HJLS
I have a set on my HJ, they are mounted from inside the mirror. Mine came off an XC. The adaptors were not needed.
Pete.
69 rust bucket Offline
#10 Posted : Tuesday, 19 April 2011 8:55:37 AM(UTC)
69 rust bucket
far out man i thought the 80's were over and done with
why drink & drive when you can drift & slide
#11 Posted : Tuesday, 19 April 2011 3:58:21 PM(UTC)
The 2000's are the new 80's....lol
dirty davo Offline
#12 Posted : Tuesday, 19 April 2011 11:21:15 PM(UTC)
dirty davo
Views messages in topic : 690
my suggestion if not keep original would be to at least keep it holden.
GTS mirrors off HJ -HZ & torana are a good thing & fit neat with adjustable pivot
i have a bundle o s/hand original ones or they make em repro now
Guest (5)
