hztonner Offline
#1 Posted : Friday, 22 April 2011 6:05:22 AM(UTC)
hztonner
HI AS I OWN A EF ON GAS IT RUNS GOOD USES NO OIL
BUT ITS BLOWING WHITE SMOKE WHEN SITTING IN IDLE
AND WHEN TAKING OFF FROM LIGHTS ONLY IT ONLY JUST STARTED ABOUT A WEEK AGO ANY ONE GOT AND ANSWER THANKS
CHEERS ALLEN
old fart racing the older i get the faster i was
Paul351xb Offline
#2 Posted : Friday, 22 April 2011 11:18:52 PM(UTC)
Paul351xb
have you checked to make sure you haven't got a head gasket going?
#3 Posted : Saturday, 23 April 2011 4:12:37 AM(UTC)
Are you losing brake fluid?
White smoke can be caused by burning brake fluid being sucked into the inlet manifold from the brake booster if the master cylinder is leaking into the booster.
hztonner Offline
#4 Posted : Saturday, 23 April 2011 7:58:44 AM(UTC)
hztonner
Thanks i will check them out tomorrow and see if its one of them
the other thing how can you tell if its head gasket going as it not missing
anywhere its running to smooth but i will check brake fluid first thanks
cheers allen
#5 Posted : Saturday, 23 April 2011 8:08:16 AM(UTC)
E Series head gasket problems normally show up with an inexplicable loss of coolant and/or rough running on startup caused by coolant in the cylinders. FWIW coolant can burn with white smoke but you would be losing a fair amount to do that I would think.
#6 Posted : Saturday, 23 April 2011 9:27:45 AM(UTC)
Auto trans & power steering oil also creates white smoke.
When the modulator in a trimatic fails, it's a perfect path for manifold vacuum to suck the oil out of the gearbox & into the inlet manifold.
Is there anything similar in one of these Fords that could allow gearbox oil to be drawn into the manifold?
You haven't had some clown connect the gearbox breather tube up to a vacuum line have you?
#7 Posted : Saturday, 23 April 2011 10:57:21 PM(UTC)
Good points Mick but no the EF does not have anything that could do that. Their power steering high pressure hose runs parallel to the exhaust manifold. Guess what happens when that hose splits? I've had it happen causing copious amounts of smoke to come from under the bonnet.
Jim...
