maccaz69 Offline
#1 Posted : Saturday, 30 April 2011 7:26:18 AM(UTC)
maccaz69
Hi guys,
I bought a vk calais efi a few wks ago but am having a mother of a time getting a rwc. First list I got had about 20 things to fix......well I finally fixed them and went back for a recheck and got told that it won't pass because the parcel shelf has been cut. Would have been nice to hear that first off but anyways I put a hell of a lot of effort into disguising this (honestly impressed myself;p) and took it elsewhere.
Well this second place picked the car to pieces with another 20 odd items (right down to rear windows needing lubrication, LHR central locking not working, spare wheel bung needs siliconing in & replacing a wheel stud because it was 'difficult' to put the nut back on etc etc etc). Anyway I fixed them all and went back only to be told that when revving the motor for a while the rear main starts to drip!
I loaded it up with stopleak and called them to see if they can check out the leak now and they said they want another $90 to do it! After twisting their arm just to look they again said the same thing. Is it normal to rev an engine to check leaks?
My question is - and all old holden fans know this - ALL holdens leak from the rear main. I have rebuilt several now and even then they leak somewhat. According to the letter of the vicroads rules they can't leak at all and this basically means all old holdens should be off the road. This car will probably leave 1 or 2 drips on the drive after you park but thats it....I have another 2 old commodores which leak much more than this does so I just can't believe it.
So I have outlaid nearly $200 in rwc tests and got nowhere does anyone know someone who is 'fair' with regard to these things? After the 2 checks the car is now perfect (other than a totally concealed cut parcel shelf and a small rear main leak) it is probably in better condition than most others on the road yet I can't get it damn roadworthied & I really don't want to blow another $90 to be told the same thing. HEEELLLPPPPPPPPPP?!??!?!!!! I'm in south east melbourne near Frankston anywhere remotely nearby would be awesome otherwise I just don't know what to do its certainly not worth pulling the motor out to replace the rear main when to me the leak is so small.....
#2 Posted : Saturday, 30 April 2011 9:16:16 AM(UTC)
Dunno about VIC laws, but annual roadies in NSW don't fail you for oil leaks - as long as they don't drip.
There can be evidence of a weep or a leak - that's fine, but if they see a drip onto the floor whilst performing the inspection, then that's an instant fail.
And I'm sorry, but I don't buy into your theory that all Holden rear mains leak. I have had numerous Holdens, all with rope rear mains, and built numerous motors for myself and for mates, again with rope mains, and none leak - I'm talking to the tune of 25-30 motors here, over a 15 year period, some with many, many km put on them since the rebuild.
Not even my 180,000km 5.0L VS has a rear main leak, and it's never been touched, so Holden got it right too.
If the rear main is done right, then you won't have any leaks.
The fact you've already loaded it up with stop-leak, and it's still leaking should tell you that action needs to be taken.
Dr Terry Online
#3 Posted : Saturday, 30 April 2011 4:15:59 PM(UTC)
Yes, I'm with Mick on this one.
While just about every car on the road has a 'wet' area under the engine (not only Holdens), there is a big difference between wetness & a full on leak.
If you can make oil appear on the ground just by revving the engine, you've got a real problem that needs addressing. Stop leak won't reduce leaks from rope seals, they are usually just a softener which will improve the effectiveness of neoprene rubber type seals.
If you really want to 'sneak' past an inspection with that leak, try running some thicker oil & less of it, say just touching the dipstick. A rear main seal is not under pressure, unless your PCV plumbing is not working, so it's only sealing against 'splash'. Just reduce the splash !!
maccaz69 Offline
#4 Posted : Saturday, 30 April 2011 10:38:10 PM(UTC)
maccaz69
Thanks guys....I have a 308 i'm building up for it so I would really be wasting time and money trying to fix the old 202....I just want the car on the road for the timebeing. It has really thick oil in it and it is pretty low on the dipstick i may try removing a bit more although I was of the impression oil from the rear bearing feeds oil to the rear main seal deliberately to lubricate it which would mean if theres oil pressure theres going to be a leak still.....The pcv appears fine as there is some vacuum at the oil filler.
I always thought the most common fault on all holdens is rear main seal- i've owned a hk, 2 hts (186 & 208), 1 hg (253) & 2 vks both 308s (excluding my current one) and every one of them would leave a couple of drops in the driveway after a drive. Maybe i've been unlucky but most of these engines were far from worn out.
#5 Posted : Saturday, 30 April 2011 11:36:12 PM(UTC)
in vic there can be no sign of any fresh leaking of any fluid, even water, old staining is ok, but I think you must've managed to pick the most perdantic mechanics in your area for a RWC, most I know of locally (wodonga) are happy if the car isn't leaking there & then & if it is, they tell you to go give it a quick wash & bring it back, if it still leaks then thats a different story.
but I was under the impression you have 28 days to have the defects re-inspected free of charge, has that changed?
Also be warned if you keep shopping around for RWC, vic roads may drop round for a visit & want to have it inspected by one of there inspectors, as it looks sus to them why all the different inspections at different locations & they do check.
maccaz69 Offline
#6 Posted : Sunday, 1 May 2011 12:49:02 AM(UTC)
maccaz69
yeah they are pedantic about it alright! I just took it to a second place and asked for their opinion on the rear main and he said that it is touch and go....he said that if I didn't mention it and there was nothing else wrong it probably would have gone through. He said go silastic the rear of the sump and the dust cover, change the oil with thick oil and see if it improves so 3rd location lucky hopefully:) Otherwise I may have to plan a trip to albury hehe
ozyjimbo Offline
#7 Posted : Tuesday, 29 May 2012 3:18:53 AM(UTC)
ozyjimbo
in vic there can be no sign of any fresh leaking of any fluid True, even water, old staining is ok, but I think you must've managed to pick the most perdantic mechanics in your area for a RWC, most I know of locally (wodonga) are happy if the car isn't leaking there & then & if it is, they tell you to go give it a quick wash & bring it back, if it still leaks then thats a different story Whats Not Leaking can't be rejected. but I was under the impression you have 28 days to have the defects re-inspected free of charge, has that changed It was never 28 Days it has always been 7 days period and as far as fees go there is no set price for a RWC some don't charge for a second inspection some do these are the types of questions one must ask before booking a vehicle in for a RWC? Also be warned if you keep shopping around for RWC, vic roads may drop round for a visit & want to have it inspected by one of there inspectors Unless a vicroads officer is switched on and has a good memory of every car to detect that one particular vehicle has been to several places for a RWC then i wouldn't be concerned, as it looks sus to them why all the different inspections at different locations & they do check.
zl296 Offline
#8 Posted : Wednesday, 30 May 2012 6:25:00 AM(UTC)
zl296
yes l have had the vic roads inspector visit me....
drove 1.5 hours to pay a visit....
wolves in sheep clothing...
beware....
