briane Offline
#1 Posted : Friday, 27 May 2011 5:36:54 AM(UTC)
briane
Hi all. The HR Prem i am playing with at the moment used to have an Aussie 4 speed in it(apparently ?)the box was not with it when I got the car. I want to put a celica 5 speed in that I have. What I would like to know , is there much modification needed to the tunnel for this to fit? Being an original Prem I am assuming the tunnel is larger to suit the original Auto that would have been there from factory. Any help would be much appreciated...Cheeers...Brian
peter_flane Offline
#2 Posted : Friday, 27 May 2011 5:52:03 AM(UTC)
peter_flane
HR has the same floor manual and auto. EH was the last body with different tunnel. The box will fit in
briane Offline
#3 Posted : Saturday, 28 May 2011 6:30:27 AM(UTC)
briane
cheers mate
adam PERTH Offline
#4 Posted : Sunday, 29 May 2011 11:07:53 PM(UTC)
adam PERTH
modify crossmember
modify speedo cable
cut another hole in your premier console further back from the aussie 4 sp.
shorten tailshaft and use toyota yoke.
change spigot bearing to suit Toyota imput shaft.
holden to toyota bellhousing with hydraulic driven clutch fork.
briane Offline
#5 Posted : Wednesday, 1 June 2011 5:11:33 AM(UTC)
briane
Thanks Adam. I have all that gear, except crossmember, The box came with a Dellow conversion kit.
Cheers......Brian
