Same age cars, couldnt tell you which ones i got it from, I think chargers have this type. Like ours, the passenger side mirror wasn't a requirement for rego, so it was an option, but a lot had them fitted as standard. I would assume that the remote wasnt considered for an optional part. How long is the arm on your original bit? |
Stepping stone or stumbling block...your choice |
which arm? the twiddly bit inside? will measure it tonight for you if you want but not sure where to measure from
I wonder if they would have allowed you to option air/steer on a 161L auto? lol I can just see the salesman 'assisting' you to drive off the lot. Could you get a 161L auto?
No, the bracket to the mirror, or the base plate mounted on the door. Just using it as a comparrison to the one i have |
will have a look tonight for you. That one you saw go for 800 must have been at the price peak? Couldn't see it going for much more than about half that now...
No, not available, they only cast an a/cond head for the 186 & 186S. The 161 head had a smaller combustion chamber. Then again the 161 lo-comp engine was fitted with a 186 head, so that is a possible build combination. Now that would have been a ball-tearer performance-wise, wouldn't it ? Dr Terry |
lol. what was the difference on the head? extra mounting boss?
Yes, extra mounting bosses on the right-hand side of the head to mount the compressor. Dr Terry |
With auto, it would probably be the only car to not get out of 1st gear over a quarter mile,,or 1/2 mile. Edited by user Friday, 10 June 2011 11:09:40 PM(UTC)
| Reason: Not specified |
It did have the accessory how to mounting documents to go with it, which were probably rarer than the part,. |
oh yeah. well according to that document my nut is mounted backwards I think. The lever would be really sticky-outy if it was mounted the other way though? lol at 1/4 mile 1st gear - is that for the glide or the tri? or both?!
you'd need a salt lake for the glide
(I did know someone who tried the reverse gear on a glide on an airstrip, but he also tried a jato on a trolley on the same strip...he reckoned the glide was only slightely less scary, but left less gravel rash) |
12k for a diff option? lol yeah I see what you mean Byron. What do you mean by GTS cabin harness? Just the dash harness or all interior wiring?
The harness from under the dash. |
hah pretty cool. Is the inside bit the same?
Toggle is the same, and I think I remember the bezel being the same as a HQ remote mirror But they are in a plastic bag somewhere with a lot of other parts i didnt want to loose, but cant place at the moment!!  Edited by user Saturday, 11 June 2011 2:30:54 AM(UTC)
For some reason a lot of the HK dash harnesses seem to go brittle, not so much for T/G. You got a NOS one? I've got a mint HK GTS one and NOS GTS HT
Joined: 16/09/2010(UTC) Posts: 411  Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
quote: Originally posted by Warren Turnbull
I have the Holden emblem/badge that goes on the HK air conditioner inside unit, most have a rubber plug.
Warren
Yes I have a few of them. Can you guess what they came off of? |
The HKTG Garage. The Home of HK HT HG Holden. |
quote: Originally posted by cloudy
Also have `Holden` body plates rectangle one from around 1927 and 2 oval ones around mid 1930`s, also a Statesman/Brougham shield made from solid resin in full colour which was originally from a Holden dealer but the wreath is missing . its approx 6x7inches and 1-2 inches thick I have never seen another in the flesh, I got it years ago from an old guy at a swapmeet.
I have one of those shields too minus the wreath. They're cool hey. I also have a complete HT Salesmans kit, 7 different coloured HK Premier 1/24 scale plastic promos and one HK Monaro, LC Torana commemorative release paperweight in the box, HK Holden board game, GTR-X Engineering Report, Original holden tooling brass embossing block for the 'Monaro' on HT GTS Doortrims, original 1967 negatives (microfishe?) of the HK Coupe body shell, HK Holden press release kit. |
well they did brag about there being 2.5 million combinations for the model, I wonder how many bought the board game for those long sunday drives
Are we there yet?? |
i have a 3 door HQ panelvan and a HQ triple gauge
This is a HK V8 auto GTS harness. Not that hard to convert to a manual one though. |
