nessyhk Offline
#1 Posted : Friday, 24 June 2011 4:24:09 AM(UTC)
nessyhk
Gday all,
Probably an age old question but i need to know what would be a better diff for my hk prem 307. i already have mocked up a vh v8 com diff 2.78 disc brake but now have the opportunity to purchase a camaro lsd diff with saddles and bump stops ( may even be a hk v8 diff not to sure but it has a big v shape curve on bak and 10 bolt without brakes can someone shed some light.
Nessyhk
Built not Bought
dirty davo Offline
#2 Posted : Friday, 24 June 2011 4:49:57 AM(UTC)
dirty davo
Originally posted by nessyhk
Gday all,
if ya want it to be original, youd need a banjo LSD 2.78 or optional 3.08 LSD. special order may have been optioned with 10 bolt, but not likely with p/glide. (would have had the hump at back of boot floor & hump at back of tank, ie would indicate original!)
th american 10bolts had different axles with chev/HQ stud pattern (groove on end of axle retained by circlip inside backing plate)
monaro used holden axle tubes & toothpick banjo axles with 28 fine spline on ends which were prone to breaking
nessyhk Offline
#3 Posted : Friday, 24 June 2011 5:10:38 AM(UTC)
nessyhk
cheers dave,
these axles are thick as, not worried about originality with drive train as it was originally a six but have a tuff little 307 to go in instead should i go with this diff as it seems stronger than the comm, also what disc brakes should i put on the camaro diff.
Nessyhk
Built not Bought
nessyhk Offline
#4 Posted : Friday, 24 June 2011 11:27:58 PM(UTC)
nessyhk
anyone else out there done this type of conversion
Nessyhk
Built not Bought
dirty davo Offline
#5 Posted : Friday, 24 June 2011 11:58:29 PM(UTC)
dirty davo
[quote]Originally posted by nessyhk
cheers dave,
[/quote
i put vb - vk com 10 bolts in hktg all th time. always just put hq rear backing plates, drums & shoes.
they dont need discs on rear. (discs drag, drums dont)
regards dave
nessyhk Offline
#6 Posted : Saturday, 25 June 2011 3:46:02 AM(UTC)
nessyhk
thanks dave hopefully hq drums fit as hq/ chev wheels are the same hey
Nessyhk
Built not Bought
Billa Offline
#7 Posted : Tuesday, 28 June 2011 3:46:36 AM(UTC)
Billa
Hi Dave,
Does anyone do axles etc to make the banjo's stronger?
I heard the BW diffs from the VL's are pretty strong and a little shorter so you can put a wider rim / tyre also.
What mods to the diff are required to do this?
Bill
dirty davo Offline
#8 Posted : Tuesday, 28 June 2011 7:30:19 AM(UTC)
dirty davo
Originally posted by Billa
Hi Dave,
Bill
to make a little stronger (& only a little)youd need fine spline axle spider gears outa hx or hz. or lx torrie . but th axles gun be too long, an need shortening (too expensve)
best to just scrap th banjo diff assy completely & source a borg warner or preferably a 10 bolt from vb to vk 5lit (big 10 bolt same as hq - z an as they are 25mm shorter & allows you to fit wider wheels) (hq - wb or chev stud pattern) otherwise hq to hz 10bolt is 26mm wider track & still good for 5 or 6"rims if not too low.(at least they tapered bearings an ya wont lose axles)
or juss pay heaps for 9" ford diff that ull drain 10 - 15% horsepower from ya motor but be bulletproof
nessyhk Offline
#9 Posted : Saturday, 2 July 2011 6:38:56 AM(UTC)
nessyhk
cheers dave already have re fabricated a vh sle comm disc brake 10 bolt to suit will stick with that just need to redrill to hq stud pattern
Nessyhk
Built not Bought
Guest (6)
