Hi All
Just wanting to pick the brains of you all as the welth of knowagle here would be a million times my own.
I own a 99 GT Forester and have been offered a striaght swap on a "genuine" HJ GTS Sedan.
Catch is the ID plates are missing, apparently stolen in 1993 but the have poilce paperwork identifing the car as a Monaro.
It has cancer in the usual spots around the vents in the back doors, bottom of back door, and passenger sill.
The Vin and engine numbers on the rego start with S and end in P (apparently the P is put there from the police check)
Car was Cream but has been sprayed GTS Red i can put up a link to photo's of the car.
Given that a genuine matching numbers GTS would probably fetch $15-$20k without the cancer is it worth me trading my $9k forester?
Thanks for taking the time to read and hopefully answer my question
its a kingswood apart from the gts wheels and yellow needle dash which the hj gts only came out with white needle dash that all it has this was for sale a while back and i actually sent this person a email stating it was a kingswood he then removed the add and now its poped back up ask him for all the numbers so you can run a check on it i bet he wont give them to you as al says DONT TOUCH IT unless you want a kingswood
+1 to what the others have said.
Without the ID plates it is not worth much at all.
With no ID plates its only worth parts and you will lose money on it, paper work stating its a GTS means nothing for the cars value without tags.Its worth as much as a series one AU falcon about $800.
Thanks: 1 times Was thanked: 243 time(s) in 217 post(s)
AU Falcon !! It's worth more than that. It's probably worth $5,000 - $6,000, as without plates it's just a V8 HJ Kingswood. It really comes down to the condition of the body & trim etc. just like any other used car. Dr Terry |
Thanks Guys,
Yeah i decided against it, tho old if its to good to be true it probably is.
Thanks for all your replies
AU Falcon !!
yes, but they are not worth $5-6000 without plates unless you have a rusty wreck to swap it too which would be frowned upon.
Is this the one? http://www.ebay.com.au/i...clk_rvr_id=245597525968
GENUINE 1976 HOLDEN HJ GTS MONARO MATCHING NUMBER CAR except the tags were stolen..... doh Edited by user Tuesday, 5 July 2011 6:49:58 AM(UTC)
| Reason: Not specified |
"Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire |
Yep thats the one, he's very generous with the discription.
The photos are old the rear door vents are completely rusted out would need to be chopped and re welded. Drivers seat has a hole in the back with foam chuck missing.
Can't be too original, HJ 308s had a turbo 400 not a trimatic. |
Cheers, Pete. Old Holdens never die, they just go faster. |
