Pacman Offline
#1 Posted : Friday, 8 July 2011 7:11:08 PM(UTC)
Pacman
So i have two guards at home that are in need of some serious TLC and i have decided that if i mess it up completely it doesnt matter but i have decided to have a shot at repairing them.
Im going to go out and buy the replacement parts, bottom, front and flutes. I was just wondering what equipment people would recommend i use and why. Keep in mind i have no welding experience at all. It will be a steep learning curve but surely it can be that hard. I dont own any kind of welding equipment so it would all be hired. Thanks in advance for your help!
Travis
#2 Posted : Friday, 8 July 2011 9:40:41 PM(UTC)
You've taken on a real task there, difficult with no skills, but not impossible.
I suggest you enroll in an evening panelbeating course at your local TAFE. I know many guys who have done this course & have just about rebuilt their entire car's body. It is amazing what you can achieve once you're pointed in the right direction.
Without that help you won't achieve a good job, it would be way cheaper & easier to buy 2 new repro guards.
dirty davo Offline
#3 Posted : Saturday, 9 July 2011 4:34:42 AM(UTC)
dirty davo
Travis
i have replacement outer guard bottoms in stock. perfect fit but need slight mods around bolt holes on bottom
regards DD
bullitljv8 Offline
#4 Posted : Saturday, 9 July 2011 5:31:56 AM(UTC)
bullitljv8
Travis
regards DD
hey davo are these chinese repo ones??? and when you say slight mods around holes what exactly do you mean???
dirty davo Offline
#5 Posted : Sunday, 10 July 2011 4:53:47 AM(UTC)
dirty davo
Travis
regards DD
no, these are made in australia.& not rare spares ones
they fit up excellent to body lines &are perfect.
on bottom where they bolt up is slightly different but fit as is. (if youre fussy, just need to rework a bit to look original)
regards DD
paech Offline
#6 Posted : Sunday, 10 July 2011 7:50:45 AM(UTC)
paech
Hi I did the same as you the guards I bought cost me about $150 for 2 they needed some rust repairs but not whole lower sections, I bought the flutes which cost around $100. The guards were fairly straight but still a lot of my free amateur panel beating skills. I measured and cut the guards for the flutes, it is best to cut accurately and butt weld these in , not overlap them. I paid a good mig welder $100 to weld them in properly making sure he did'nt put too much heat into the guards so you dont get any warpage. I have limited welding skills but with a bit of practise and the mig set low you can have a crack at the lower repairs or simply do all the time consuming prep work and once again pay a good welder to do the welding . The guards are now on the Warwick Yellow HK GTS ute and look great.Summary:you cant buy original gts guards, the new ones are good but will cost $2000.00, mine cost around $500, your's will cost a bit more but you will have done it yourself, learnt something, and you'll have $1300.00 to spend on N.O.S. windscreen wiper inserts.LOL.
dirty davo Offline
#7 Posted : Monday, 11 July 2011 3:21:12 AM(UTC)
dirty davo
youd be better off using original flutes cut out of genuine stuffed guards as the repro ones arent pressed propperly & look nothing like originals (ie rounded edges like 4/10)
regards DD
