karlee Offline
#1 Posted : Friday, 29 July 2011 7:59:58 PM(UTC)
karlee
hey guys, im looking for a extension housing seal for a lj torana. cant seem to find one anywhere!
the original part number is 8850997
if anyone can help me out or even know if i can get one made up that would be great!
thanks
#2 Posted : Friday, 29 July 2011 8:04:49 PM(UTC)
What type of gearbox ?
3-sp manual, 4-sp manual & Tri-Matic all use the same rear seal & they as common as. Any transmission shop will have a box full.
hqgts Offline
#3 Posted : Saturday, 30 July 2011 2:23:16 AM(UTC)
hqgts
thanks
go into any autopro and ask fro a kelpro seal part number 97123
should be about $5 and as Dr Terry says fits most applictions
Al
Edited by user Saturday, 30 July 2011 2:25:03 AM(UTC)  | Reason: Not specified
#4 Posted : Saturday, 30 July 2011 2:51:30 AM(UTC)
That's why I asked what type of gearbox. karlee didn't say what type of LJ it was. It could be a 1300 4-cyl 4-sp Vauxhall box, especially with the strange part number quoted.
BIGCAV Offline
#5 Posted : Saturday, 30 July 2011 3:45:52 AM(UTC)
BIGCAV
the number suits a 1760 eng
dirty davo Offline
#6 Posted : Saturday, 30 July 2011 5:49:12 AM(UTC)
dirty davo
thanks
i just assumed you would have 6cyl traumatic or 3 or 4spd aussie!!
best bet is to pop ya old one out & take to any reputable bearing supplier & they can supply you with a seal with double lip as per original rather than a single lip seal that is common at all supercheap outlets that ul only last thru yor RW inspection, then give you greif soon after!!!!!!
may cost you 15 - 20 bux instead of 5, but ya get what yas pay for aye??????
regards DD 0412109239
karlee Offline
#7 Posted : Monday, 1 August 2011 10:23:15 PM(UTC)
karlee
thanks guys. yeah its a 1760cc 4spd manual. i had the old one taken out and was wrecked. i tried heaps of bearing or seal manufacturers and no-one would even bother trying to make a duplicate of it. it's a hard one to find because it goes on the outside of the housing rather than the inside.
thanks heaps :)
karlee Offline
#8 Posted : Tuesday, 2 August 2011 10:59:10 PM(UTC)
karlee
hey dr terry and hqgts, ive got that seal number 97123 and its not the right one. its different to what i need.
the dimensions of the seal i have is 25.8mm width, 59mm outer diameter and 44.8mm inner diameter. do you have any ideas?
#9 Posted : Tuesday, 2 August 2011 11:11:09 PM(UTC)
karlee, seal number 97123 is the one that fits the normal 6-cyl boxes.
As you say, the Vauxhall box has a seal which fits over the outside of the extension housing. You may need to go to ebay U.K. & try there to get the correct Pommy seal.
karlee Offline
#10 Posted : Tuesday, 9 August 2011 6:42:50 PM(UTC)
karlee
i have the 97123 seal right here and it doesnt fit. and its a 4cyl not a 6 cyl like i said earlier. its a 1760cc 4spd manual. it has an opel engine
AMunro327 Offline
#11 Posted : Tuesday, 9 August 2011 7:46:42 PM(UTC)
AMunro327
Dr Terry could be on the money with his suggestion to go to Ebay UK. Had a quick look there, does this seal in this listing look like what you want?
http://www.ebay.co.uk/it...s_SM&hash=item20bbad8eaa
#12 Posted : Tuesday, 9 August 2011 8:59:34 PM(UTC)
karlee, your engine & gearbox are of Vauxhall origin, they are not Opel.
This might be worth a try, or contact the seller, he seems to specialise in this stuff.
http://www.ebay.co.uk/it...8418e4c4e#ht_2280wt_870
