4 Pages«<234
petaus Offline
#61 Posted : Tuesday, 27 September 2011 8:15:00 AM(UTC)
petaus
does any one have a hk build sheet they can post up???
did it have a allocated firewall number and vin tag number????
one thing if fint interestine is they allowed differnt plants to stamp the tags in
a different manor from one another.
petaus Offline
#62 Posted : Tuesday, 27 September 2011 8:25:30 AM(UTC)
petaus
i wounder if they had stuff up like 81837 with the wrong front floor i.e no sag hump??? turn it back to a737?
or a belmont with sag hump floor lol
#63 Posted : Friday, 30 September 2011 3:09:45 AM(UTC)
About the same chances of an Ek being fitted with a manual floor instead of an auto floor.
Warren
The HKTG Garage Offline
#64 Posted : Thursday, 13 October 2011 5:44:04 AM(UTC)
The HKTG Garage
OK, I finally had some information passed on to me to day in relation to the firewall stamping (well at the Elizabeth Plant). A long time employee I know that works there asked a fellow employee that actually worked on the HK HT HG models in the Body shop. He had the job of stamping the firewall. He said the numbers were stamped into the panel as it lay horizontally in the press. He said the numbers were entered into a machine and it stamped it accordingly. The numbers were NOT in sequence. They were allocated to each job as per broadcast sheet. I am still clueless as to why some have a second letter stamped beneath and some dont. The employee still works there.
Sebring Orange Offline
#65 Posted : Friday, 14 October 2011 5:09:19 AM(UTC)
Sebring Orange
One number on top of each other is because the Bodys were made at one plant ie Panel Vans at Adelaide only and then completed at another plant which then got that State Letter stamped . Normally crooked and would break the paint .
#66 Posted : Friday, 14 October 2011 6:20:58 AM(UTC)
The HKTG Garage
This is not the case. As an Adelaide based dismantler I have probably 90% Adelaide build HKTG in my yard. I have only seen two with a double 'A' stamped. I have an HK Premier Adelaide built and sold at United Motors in Adelaide ( I have the books and have had the car for 17 years. It has an 'A' below the 'A'.
What about the Sydney cars with 'S' upon 'S'?
#67 Posted : Friday, 14 October 2011 8:21:26 AM(UTC)
Simon, it is only HD to HK that have the double letters, HT was not suppose to have it.
ALthough some plants did continue into early HT.
Warren
Guest (8)
4 Pages«<234
