28 Pages«<45678>»
the eh Offline
#101 Posted : Monday, 24 December 2012 4:43:37 AM(UTC)
the eh
Best thing about Christmas holidays is that I finally get time to CLEAN UP. Although everything looks like it's everywhere it is all in it's place and there is actually room to work on both benches.
Finally got our old plasma TV to use in the garage. It weighs about 40kg is only analogue and standard definition. This $5000 TV has been replaced by a $400 Laughing Horse brand from China..
the eh Offline
#102 Posted : Friday, 4 January 2013 5:41:58 AM(UTC)
the eh
New years project. This is a engine stand that will allow me to start and run an engine with or without a transmission. It has locations for a fuel bottle and battery as well as a removable radiator mount. There will also be a simple wiring harness with ignition, start, oil light and temp gauge. I'll also try to squeeze in a muffler or two if possible.
I dug out the control box I used with THE EH before it was wired. This contains a main ignition switch and lamp, A VDO water temp gauge, a low oil pressure lamp, a start button and also a thermo fan switch.
Also found a left over tacho, water temp, oil temp and oil pressure gauge. I'll mount this on the frame also to help keep an eye on things.
Transmission mount made but not final welded.
38mm Denso style EFI pump fitted to the frame. This will be gravity fed from the fuel can.
Edited by user Tuesday, 31 December 2013 6:12:12 PM(UTC)  | Reason: Not specified
the eh Offline
#103 Posted : Friday, 4 January 2013 5:45:24 AM(UTC)
the eh
Mockup in cardboard of a 30 row oil cooler that I was thinking of adding to the cooling system. The coolers run AN10 fittings and should easily tap into the heater hoses under the passenger side guard. I am contemplating running 2 of these with fans mounted under the car just in front of the diff. This is if I can get them to fit.
10 inch fans fitted. These would run at all times the coolers are being used. I may control them manually, via a separate thermo switch or via the PCM. Not sure at the moment.
the eh Offline
#104 Posted : Monday, 14 January 2013 3:05:42 AM(UTC)
the eh
Initial fitting of the engine and trans. This allowed me to determine the trans mount height. It was then welded off..
Drivers side pipes are very short to give clearance around the steering rack in the Commodore. This is no good for my so the collector will be lengthened and modified to turn the collector to a more usable angle.
Passenger side was more fiddly as the headers are longeron this side and I also needed to make this side match the other side. However it was still reasonably straight forward.
Completed, O2 sensor now is positioned in the front sensor position in the engine pipe. Apparently the original Commodore position in the header will cause the sensor to foul on the tunnel.
Engine pipes complete. I gave up trying to make them to also suit the one tonner when I'm finished here. I'll just redo a set for the car once the engine is in.
the eh Offline
#105 Posted : Monday, 14 January 2013 3:09:04 AM(UTC)
the eh
Fitted a low pressure fuel pump also to the stand. I can now run carby and EFI systems.
I removed the EFI throttle body, all the wiring, fuel rails etc to allow me to start the motor with a carby. I'll change the dissy to a Bosch HEI and away we go.
greenhj Offline
#106 Posted : Monday, 14 January 2013 3:42:20 AM(UTC)
greenhj
after seeing your build and the obvious work you put into the most minor of details, the injector blockoffs seem a tad low tech :D
the eh Offline
#107 Posted : Monday, 14 January 2013 5:00:17 AM(UTC)
the eh
No they'll be ok. Used rubber globes are good for many jobs..
Seriously though. I have a small length of 15/16" HEX aluminium left. I'll just machine up some from that when I get a chance.
the eh Offline
#108 Posted : Friday, 25 January 2013 4:58:08 AM(UTC)
the eh
Dashboard for the engine stand will be this a;uminium box. It will house the switches, relays and gauges needed to keep the engine running sweetly.
To run the motor on the stand with a carby I needed a stand alone electronic dissy. Luckily I sell them so getting one was no problem. A bit of cam lube on the gear and a few squirts of oil in the oiling hole and around the end of the shaft will ensure there is no dry startup.
Aftermarket aluminium dissy clamp needed a slight radius ground into it to clear the Torque Power inlet manifold.
All the engine wiring is complete. Once I'm sure it's all ok I will cable tie everything together and terminate all the cables at a pair of 6 pin connectors.
Oil pressure sender and oil pressure switch fitted to the oil pump using an adaptor I had left over from the EH build.
BA alternator mounts differently to the Holden style. However I was able to mount on on a standard Holden mount and a simple adjuster will help tension the belt. This is only for use on the engine stand.
600 squarebore Holley was cheaper NEW than a second hand reco unit. Go the Aussie dollar..
the eh Offline
#109 Posted : Friday, 25 January 2013 5:09:50 AM(UTC)
the eh
Ebay special 3" stainless mufflers. These will be used on the stand then in the HZ once it's ready.
Main power distribution for the control box. Everything has been scrounged from other projects or is leftover from other jobs.
Oil pump was as dry as the Simpson desert. Luckily I didn't try to start the motor with this as it is.
Control box wiring complete. Still waiting on a starter button though. Once it's fitted I'll close things up and mount it on the stand.
Bay trans cooler with thermostat and 7" thermo fan from the leftovers cupboard.
eBay bling
the eh Offline
#110 Posted : Sunday, 24 February 2013 3:55:28 AM(UTC)
the eh
Control box complete
10 litre fuel cell fitted and plumbed to both high and low pressure pumps.
Radiator was positioned so that the standard HZ hoses can be used.
Exhaust fitted and only needing muffler supports. These will brace back to the gearbox mount keeping everthing above the mounts so it all moves together.
the eh Offline
#111 Posted : Wednesday, 3 April 2013 4:34:56 AM(UTC)
the eh
Added a nice set of Bosch Ignition leads with heatshields.
the eh Offline
#112 Posted : Wednesday, 3 April 2013 4:41:53 AM(UTC)
the eh
Whilst looking at ignition leads I came across a problem with the EH leads. Number 3 had melted through the boot and was arcing on the exhaust.
I searched the internet and came up with this product as the best/easiest solution.
Here's the results
Edited by user Wednesday, 3 April 2013 4:44:24 AM(UTC)  | Reason: Not specified
ehwa Offline
#113 Posted : Friday, 5 April 2013 5:58:30 AM(UTC)
ehwa
bloody nice job on the eh, looks fantastic you be should be very happy with how it turned out, just a quick question what steering column did u use cheers mate
the eh Offline
#114 Posted : Saturday, 6 April 2013 3:48:04 AM(UTC)
the eh
Thanks,
The steering column tube is a HQ lower section joined to a VS Commodore upper section. The shaft is a VS Commodore upper with a HQ intermediate section and a Torana lower section. All 3 use the same shaft dimensions which allows the sections to simply slide together. Once assembled I drilled them and used an aluminium shear pin to hold the sections together. This allows the column to remain collapsible.
greenhj Offline
#115 Posted : Thursday, 11 April 2013 6:45:29 AM(UTC)
greenhj
when are you hooking up a water brake and some strain gauges to the engine run in stand? :D
the eh Offline
#116 Posted : Monday, 15 April 2013 6:59:54 AM(UTC)
the eh
Not quite. I don't think I would even bother to put this engine on a dyno. It's a mild setup probably only putting out 350HP max. It would probably not even register on the dyno..
the eh Offline
#117 Posted : Monday, 15 April 2013 7:04:18 AM(UTC)
the eh
Here's a couple of other projects I did recently. First is a Commodore wiper motor for an EJ,EH and the second is a mounting kit for a Sanden 508 compressor on the passenger side head of a 253-308 carby or EFI.
the eh Offline
#118 Posted : Sunday, 9 June 2013 6:45:39 AM(UTC)
the eh
One front wheel was not sitting on the hub flush. Turns out 2 of the countersunk rotor mounting bolts were sitting proud. A quick linish and a repaint and it's fixed.
Finally fitted the repro 1964 rego label..
Thought I would try out the new (to me) mill by slotting some slotted rotors I had left over from the EH build. These are 343mm HSV rotors with 8 slots. I added another 16. It was a learning experience. All I need to do now is the other side and the complete other rotor.
Bonnet clearance is about 8-10mm betweenthe air filters and bonnet. You wouldn't think so looking at the filters in this shot
KeithA Offline
#119 Posted : Sunday, 9 June 2013 7:43:44 PM(UTC)
KeithA
You do some great work and I'm always interested in watching it. Keep it up.
Keith
the eh Offline
#120 Posted : Monday, 10 June 2013 4:02:04 AM(UTC)
the eh
Thanks Keith, I like to tinker in the shed and some times things work and some times they don't. I don't post the failures however. Haha..
Guest (6)
28 Pages«<45678>»
This page was generated in 0.178 seconds.
