Thanks: 8 times Was thanked: 16 time(s) in 14 post(s)
instead of pinning to the head, how about using studs rather than bolts.
Something like a modified socket shoulder screw with a thread at both ends?
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
I am already using studs. I would need to make some bushes to match the 3/8" studs to the 12mm holes in the plates. Either bushes or pins will work so long as each plate stays with the port it is matched to.
Basic profile machining of the wiper motor mounts complete. 9 pieces here all machined together to ensure consistency.
Wiper kits complete. First batch all sold. If you're interested in one let me know. I should have more made in a few weeks time. Complete kit as shown with a used motor is $250 or $320 with a new Genuine Holden motor. Postage is $20 Australia wide via EXPRESS POST.
2 NEW Holden wiper motors for 2 wiper conversion kits. One heading to Northern Qld and one to Tasmania.
Exhaust FINALLY finished. Took 2 goes to get it right. I still need to install it with gaskets and sealant. I also need to run the wiring through the floor and wire a switch to operate the cutout.
Dear Lord!! What a fantastic car! How on earth do you keep motivated for that long? I can't see any detail that you haven't attended to or thought about! But there must be SOMETHING your not happy with, yes? Naaa! It's outstanding, nice work and congratulations!
Thanks Trev, yep it's an obsession that I enjoy. There are lots of things that can be done and redone and one day I will get to them.
I had to redrill another seat bracket bolt as it was a more convenient location for the exhaust cutout wires to pass through.  Bolt reinstalled and awaiting the wiring  Exhaust cutout wires fitted and ready for connection. The switch will be hidden in the console compartment.  This is the view of the drivers side floor with the seat removed..
who built the front end and does it come with engineers paperwork?
The front end is from Southern Chassis Works and comes with all engineering documentation needed. http://curleys.com.au/
https://www.facebook.com/SouthernChassisWorks
I don't have it as yet so can't answer any questions about it other than what's shown in his site. Once it's here I'll post up some pics..
I found a solution for my steering shaft conversion that will be needed when I change to the BMW power rack. SCW modify a Borgeson uni joint to fit the rack and accept 3/4" DD steering shaft. Borgeson now make a uni joint that adapts 3/4" DD shaft to the standard Torana 9/16" cotter pin setup. This means my steering column can stay as it is and all I need is a length of 3/4" DD shaft which I will get when I get my rack conversion..
Always good to have a spare.
I wasn't going to pay $100 for a piece of 3/4" DD steering shaft as I think it's too expensive. This 1.2m length of 3/4" bright steel cost me $9.45. All I have to do is machine 2 flats on each end and it's done. Here it is with the new universal joint fitted..
