Fastlane
Holden Forums
Holden General Discussion
VR Statesman Steering stiff advice please
The steering on my car is reallly stiff and making a winy noise when i turn iv topped up power steering fluid b ut still hapening. Is it deffinitly the steering rack or something else anyone with an idea on costings
Thanks: 1 times Was thanked: 35 time(s) in 33 post(s)
VR statos have variotronic steering, and the pressure (and therefore assistance) is controlled by the pressure modulator solenoid (which is controlled by the BCM in relation to road speed).
I would check all the connections for the solenoid - at the ra |
Thanks: 1 times Was thanked: 244 time(s) in 218 post(s)
Hi Guys.
If the solenoid or the electronics fail on a Variatronic system you still get quite a bit of power assistance. I certainly wouldn't call it 'really stiff'.
The most common fault in these cars is that the plastic piston in the rack valve bre |
Fastlane
Holden Forums
