3 Pages<123>
ausmulishatroop Offline
#21 Posted : Saturday, 26 November 2011 12:57:27 PM(UTC)
ausmulishatroop
EH Has returned Home so I can Begin to Assemble all the Little Pieces for when the Motor is ready to be Placed back in the Engine Bay for the First time.
#22 Posted : Saturday, 26 November 2011 1:01:05 PM(UTC)
ausmulishatroop
Whilst waiting for the motor i had cleaned all the inside floor pan's and also Sealed and Treated the Floor Pans with Kill Rust Treatment. This Turned out Mickey Mouse , I was very happy with end result. Gives the Floor more lease to life and also allow Floor to last longer.
#23 Posted : Saturday, 26 November 2011 1:01:37 PM(UTC)
ausmulishatroop
#24 Posted : Saturday, 26 November 2011 1:09:26 PM(UTC)
ausmulishatroop
Whilst Motor was been rebuilt , re Machined , Bored and etc Rhys and I Rebuilt a HR Disc Brake Front End from Ground up with all new Parts including Brake Caliper's , Rotor's , Spring's . Ball Joint's . Stub Axles , Wheel Hub's , Wheel Bearings and Every Other Component involved in the Front End. This was a Complete Brand New Disc Brake Front End.
#25 Posted : Saturday, 26 November 2011 1:13:46 PM(UTC)
ausmulishatroop
Photo of the Front End in Progress of being Built, All Mod's and moving and Welding of Engine Mount's were Fitted and Welded by My Self (Clint Fewster)
#26 Posted : Saturday, 26 November 2011 1:15:20 PM(UTC)
ausmulishatroop
Freshly Painted and Ready for Assembly
#27 Posted : Saturday, 26 November 2011 1:20:14 PM(UTC)
ausmulishatroop
Ready to Install The Disc Brake Front End Ready For The Re Conditioned Motor Install
#28 Posted : Saturday, 26 November 2011 1:23:06 PM(UTC)
ausmulishatroop
All Installed and Fitted. No Drama's had come through with the Install luckily. Surprisingly every thing is just going to smooth...Hope every thing else turns out just as smooth...
#29 Posted : Saturday, 26 November 2011 1:28:22 PM(UTC)
ausmulishatroop
So We Rebuilt the Complete Front End so why Not Rebuild The Ass End , Diff and Rear Suspension. Why Not so here we go... Removing all Parts
#30 Posted : Saturday, 26 November 2011 1:38:47 PM(UTC)
ausmulishatroop
New Brake Shoes and Wheel Cylinders were Needed to be Replaced in the diff Due to Disc Brake Upgrade of the front, New Nolathane Bush's were Installed and New Rear Shock Obsorber's were also a Priority replacement.
#31 Posted : Saturday, 26 November 2011 1:40:27 PM(UTC)
ausmulishatroop
The Finished Product - Rebuilt Diff
#32 Posted : Saturday, 26 November 2011 1:41:30 PM(UTC)
ausmulishatroop
And Then The Install of the Rear Diff and Suspension
#33 Posted : Saturday, 26 November 2011 1:49:06 PM(UTC)
ausmulishatroop
Its been about 3 months since all was started and things are progressively moving forward very fast... Helps Good when your Best Mate owns his own Mechanic Shop which gives me access to all tools that are required and Parts Required for rebuild. Every little thing helps in a big way.
EH Back on all 4 Wheels since Engine Bay Re Spray , Installed New HR Disc Brake Front End and Rear Rebuilt Diff and New Front and Rear Suspension. Ready waiting patiently for the Motor Now
#34 Posted : Saturday, 26 November 2011 1:52:12 PM(UTC)
ausmulishatroop
Motor is Slowly Returning From Machine Shop , The Head has Returned from the Head Re conditioner's and the assembly is slowly coming together....
#35 Posted : Saturday, 26 November 2011 1:58:30 PM(UTC)
ausmulishatroop
Motor is a 202 Blue bored out to 208ci with a 12 Port Head that has Been Bored out 60' Thou and recondition with Over Size Valves and Springs, Motor also has A Mild Cam and Crank has been re - Ground and Balanced . ACL Racing Rebuild Kit has Been installed through out Motor. Running HQ Flat Top Racing Pistons and 350 Holley Carb and Manifold.
#36 Posted : Saturday, 26 November 2011 2:01:01 PM(UTC)
ausmulishatroop
Plan on Installing a New Set of Pace Maker Extractor's and a 2 - 1/2 Inch Exhaust and Sports Muffler. That should give me a tidy sounding note from the rear end.
Edited by user Saturday, 26 November 2011 2:07:36 PM(UTC)  | Reason: Not specified
#37 Posted : Saturday, 26 November 2011 2:06:33 PM(UTC)
ausmulishatroop
Car has Returned back to the work shop ready for Motor to be Dropped in for installment. Things are coming together Great. All thanks to Dave Davies and Rhys Davies @ Port Kennedy Mechanical and Radiator Repairs.
#38 Posted : Saturday, 26 November 2011 2:13:34 PM(UTC)
ausmulishatroop
Motor is now sitting in the Engine bay and looking sweet. Everything went smoothly as usual as Rhys would Say. Engine Mounts seem to be in the Correct Position for Motor we have clearance around the Fire Wall near Gear Box Tunnel so this is all Positive so Far for Install...
#39 Posted : Saturday, 26 November 2011 2:15:11 PM(UTC)
ausmulishatroop
Very Happy and Very Tidy Looking......WOOOOO HOOOOOOOO Progress
#40 Posted : Saturday, 26 November 2011 2:17:31 PM(UTC)
ausmulishatroop
Motor Slowly Coming to the point for its First initial Start Up. All Dress Up Parts are slowly Coming in as well. Bit by Bit the Car is starting to look like a Car once Again..
3 Pages<123>
