edelbrock1 Offline
#1 Posted : Monday, 28 November 2011 6:32:56 AM(UTC)
edelbrock1
Today at the SA Monaro State Titles we had a bit of a discussion on the dog leg on the rear view mirror on early Monaros. Not much seems to be known about it.
What is it for?
What models should have it?
The HKTG Garage Offline
#2 Posted : Wednesday, 30 November 2011 5:32:52 AM(UTC)
The HKTG Garage
Under Group 10.185 of the yellow HK series parts catalogue, the interior mirrors are not specified to one model but all in the HK range. Just the two types, anti glare and normal.
les Offline
#3 Posted : Wednesday, 30 November 2011 6:23:52 AM(UTC)
les
I found 3 part numbers for the mirror only 7417096 plain 2806777 plain 7430042 anti glare
and 2 part numbers for the mirror with support M36555 & M36556 I used the blue book
not sure what is meant by the dogleg is that the pivot.
edelbrock1 Offline
#4 Posted : Wednesday, 30 November 2011 7:57:45 AM(UTC)
edelbrock1
I will dig up a picture. You have the normal mirror stem, and then a dog leg addition and then the mirror. I was told it was for the coupe and the lower back window height.
I thought Warren or Byron would have had an idea.
dirty davo Offline
#5 Posted : Thursday, 1 December 2011 6:41:18 PM(UTC)
dirty davo
th longer (dogleg) mirror extension arm is on all HT & HG prem sedans, brougham & panelvans, to allow for small rear window
tiz also on monaro to allow for more angled window
was an improvement from HK although some late Ks may have got em
regards DD
#6 Posted : Sunday, 4 December 2011 7:05:15 AM(UTC)
Was in the first ammendment to the yrllow book and my HK, a July 68 build, rego 8/68 had it.
Warren
80569K Offline
#7 Posted : Wednesday, 7 December 2011 2:59:22 AM(UTC)
80569K
Is the dogleg part of the mirror head or is it a separate part?
edelbrock1 Offline
#8 Posted : Wednesday, 7 December 2011 3:50:33 AM(UTC)
edelbrock1
It is separate.
Imagine a normal mirror and a normal mirror stem. But between the two, there is a boomerang shaped bit of metal, that drops the mirror lower. Supposedly to allow you to see out the back window in the coupes.
80569K Offline
#9 Posted : Wednesday, 7 December 2011 4:08:31 AM(UTC)
80569K
Cheer's mate, I'll be looking for a "dogleg".
Guest (5)
