phill Offline
#1 Posted: : Friday, 2 December 2011 12:03:00 AM(UTC)
phill
Hi guys in my XB I now have the Oil Pressure working and its reading about 85% -90% is this right for an XB? where shoud should the needle sit on the guage when its correct?
Cheers Phill.
HQ Sandman Offline
#2 Posted : Friday, 2 December 2011 3:37:53 AM(UTC)
HQ Sandman
Is this while idling or when you are cruising?
phill Offline
#3 Posted : Tuesday, 6 December 2011 1:39:19 AM(UTC)
phill
This is at idling, but on the weekend I took it for a good drive and gave it a bit and went down to about 60%, so I'm guessing it could be working?
HQ Sandman Offline
#4 Posted : Tuesday, 6 December 2011 8:46:11 AM(UTC)
HQ Sandman
I have a HQ Holden and while idling, it is at around 10% and while driving around 50%. Unsure if yours is wrong or mine. It never has gone above 50%.
#5 Posted : Tuesday, 6 December 2011 8:55:17 AM(UTC)
The oil pressure should normally read about 1/2 when cruising and drop a bit at idle especially on a hot day.
Factory oil pressure gauges are not overly accurate so if you are worried about it get it checked with a more accurate mechanical gauge.
phill Offline
#6 Posted : Wednesday, 7 December 2011 4:12:32 AM(UTC)
phill
ok, that helps, thanks guys.
Cheers Phill.
HQ Sandman Offline
#7 Posted : Wednesday, 7 December 2011 8:19:26 PM(UTC)
HQ Sandman
Thanks Jim.
