Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi All, Will someone who knows their HQ through WB's let me know specifically what setup these brackets suit? I know they are 253, 308 and assume they suit the big black "Frigidaire" compressor. If this is not correct I stand corrected. Is this a complete setup? Any help will be greatly appreciated.
The set up is not complete, you will also need the engine mount bracket, passenger side, for the brace to bolt to.
Warren
Thanks for that. I do have the mount with the tab welded to it. If that then makes the setup complete I am happy. Do you have a link to any pics of the setup fitted.
quote: Originally posted by Warren Turnbull
The set up is not complete, you will also need the engine mount bracket, passenger side, for the brace to bolt to?
Warren
Edited by user Sunday, 1 January 2012 8:23:24 AM(UTC)
| Reason: Not specified
You have all the brackets, just the spacers are needed and yes this is for the fridgidair compressor.
Warren
Thanks Warren
Warren
