munro1656 Offline
#1 Posted : Wednesday, 4 January 2012 8:11:57 PM(UTC)
munro1656
Hi all I am new here and just have a quick question for you on my diff. now when I bought the car I was told that it had a salibury 10bolt with 4.11's and LSD so after driving car for a while it didn't have the feel of 4.11 so I counted the turns and it only about 3.7 that makes me think is it a 10 bolt or not.I was hoping there was some obvious markings for a 10bolt on the casing or something. I should mention to you that it's not fitted in to a holden its accually running in a escort with a 3lt v6 efi turbo with a 904 torque flight trans.
gmholdman Offline
#2 Posted : Wednesday, 4 January 2012 11:46:33 PM(UTC)
gmholdman
Easy...count the bolts ??
munro1656 Offline
#3 Posted : Thursday, 5 January 2012 12:06:46 AM(UTC)
munro1656
I was hoping not to have to pull the centre cover off to count the crown bolts would you happpen to know if there is any external indentifacations at all ????? cheers craig
#4 Posted : Thursday, 5 January 2012 12:35:15 AM(UTC)
Take a photo of the rear cover and post up a link
munro1656 Offline
#5 Posted : Thursday, 5 January 2012 5:37:58 AM(UTC)
munro1656
I have taken a couple of photo's but have not a clue on how to post any one got a quick lesson for me???
#6 Posted : Thursday, 5 January 2012 7:31:09 AM(UTC)
Put them on a photo hosting site like photobucket and post up the link. If you do a search on this site there is a thread on it somewhere.
HQ Sandman Offline
#7 Posted : Friday, 6 January 2012 4:54:40 PM(UTC)
HQ Sandman
Munro,
You just need to count the bolts on the outer casing. In reference to the ratio, you need to take the outer casing off. On the main sun dial it should be stamped what the ratio is.
#8 Posted : Friday, 6 January 2012 7:52:18 PM(UTC)
Bolts on the outer casing won't tell you anything.
#9 Posted : Friday, 6 January 2012 8:50:41 PM(UTC)
I know it's not foolproof & there are exceptions, but I use the lid bolt count as a quick ID over the phone.
12 bolts = 12 bolt Chev
10 bolts = 10 bolt Chev or Holden Salisbury
9 bolts = BW 78
If the ratio is 3.7 & it has 9 bolts holding the lid, then it's probably a BW out of Nissan Skyline R31, a common conversion in small cars like Escorts.
HQ Sandman Offline
#10 Posted : Saturday, 7 January 2012 5:02:21 AM(UTC)
HQ Sandman
Sorry HK,I am not much of a mechanic, but I agree with Dr Terry.
Please fill me in if I am missing something.
#11 Posted : Saturday, 7 January 2012 5:18:45 AM(UTC)
Number of bolts is the bolts that hold the crownheel to the hemisphere, not the cover plate. Dr Terry's rule of thumb works in some instances (like if you have a 12 bolt). Won't help you tell Holden small and big Salisbury diffs apart or pick between them and Chev 10 bolt.
adam PERTH Offline
#12 Posted : Saturday, 7 January 2012 11:54:46 AM(UTC)
adam PERTH
the only way to tell the ratio without taking the rear cover off or trusting a 35 year old yoke flange is to jack up one wheel and cound the 1/2 turns the tailshaft does.
3.5 half turns (180 Deg) of tailshaft it will be 3.55 etc
#13 Posted : Sunday, 8 January 2012 11:32:26 PM(UTC)
Correct, the number does refer to the number of crownwheel bolts, my example was just a quick ID method in case his was a BW.
Guest (5)
