andkno21 Offline
#1 Posted : Monday, 9 January 2012 4:37:00 AM(UTC)
andkno21
Hi,
I have just purchased a 350 chev and need some help identifying some parts. Inlet manifold GM 346249 and a 10 under that number,
engine 10L1.....on the rhs front near head. I assume this is the engine serial number, 3970014 K7 8 T24 350chev not sure if 2 or 4 bolt (need to take sump off to see I guess)and heads 3932441,
Any help would be appreciated,
Regards
Andrew
petaus Offline
#2 Posted : Monday, 9 January 2012 8:52:46 AM(UTC)
petaus
the intake is , 76-82 305-350 cast iron intake q-jet with egr provision,
blockccould be from 69-79 2 or 4 bolt 69- 74 441 could be one of the fuel heads from memory, the combustion chamber is filled in a bit more near the spark plug.
pete.
sexc351 Offline
#3 Posted : Monday, 9 January 2012 10:12:41 PM(UTC)
sexc351
this might help with heads
http://www.fastnuf.com/Headguide.html
petaus Offline
#4 Posted : Monday, 9 January 2012 11:27:20 PM(UTC)
petaus
041 are the fuelies is was meaning not 441
#5 Posted : Tuesday, 10 January 2012 1:06:43 AM(UTC)
441 are the heads used on HT-HG 350 auto and early type HQ 350 engines. Worth something to the right person.
andkno21 Offline
#6 Posted : Tuesday, 10 January 2012 7:44:20 PM(UTC)
andkno21
Thanks for the info everybody...I am told that the inlet manifold was supposed to be used on a monaro and may be of some value...Can anybody help in verifying this at all. Regards Andrew
andkno21 Offline
#7 Posted : Tuesday, 10 January 2012 7:45:43 PM(UTC)
andkno21
Sorry . Didn't supply number of inlet manifold GM 346249
adam PERTH Offline
#8 Posted : Tuesday, 17 January 2012 7:58:34 AM(UTC)
adam PERTH
i saw on one of the lists on the net that 3970014 block cast is is LA built Camaro... i have 2 thats why i remembered...
