Hi, I have just purchased a 350 chev and need some help identifying some parts. Inlet manifold GM 346249 and a 10 under that number, engine 10L1.....on the rhs front near head. I assume this is the engine serial number, 3970014 K7 8 T24 350chev not sure if 2 or 4 bolt (need to take sump off to see I guess)and heads 3932441,
Any help would be appreciated, Regards Andrew
the intake is , 76-82 305-350 cast iron intake q-jet with egr provision, blockccould be from 69-79 2 or 4 bolt 69- 74 441 could be one of the fuel heads from memory, the combustion chamber is filled in a bit more near the spark plug. pete.
You have been a member since:: 18/08/2008(UTC) Posts: 82
041 are the fuelies is was meaning not 441
441 are the heads used on HT-HG 350 auto and early type HQ 350 engines. Worth something to the right person. |
Thanks for the info everybody...I am told that the inlet manifold was supposed to be used on a monaro and may be of some value...Can anybody help in verifying this at all. Regards Andrew
Sorry . Didn't supply number of inlet manifold GM 346249
i saw on one of the lists on the net that 3970014 block cast is is LA built Camaro... i have 2 thats why i remembered... |
