#1 Posted : Wednesday, 2 June 2004 2:24:23 AM(UTC)
hi guys,
jus regarding my 308 HJ ute, backed up by a 2speed. I was dragging the other nite,on my own private strip :). and on about 300metres my car started starving for fuel, so i had to back of and only run 3qaurter throttle. Now the question is, will changing the float level in the quadrajet do anything to help??or should i upsize the jets a little, iam running size 76jets atm in a prepollution carby, and the guy at the carby place said these will be big enough as they were used in the brock commodores, but i think the 2speed might be asking more from the motor...or could it be something entirely different???
Also on an argument i was having with my brother, will a motor detinate if it is starved of fuel??
thanks guys
john...
#2 Posted : Wednesday, 2 June 2004 4:22:41 AM(UTC)
Early quadrajets known to starve on drag strip. On stock early 308's the 4MV quadrajets run #76 jets for auto transmission (45B pins), but run #77 jets for manual transmission. If your engine has any work done (even just ignition and extractors) than you
#3 Posted : Wednesday, 2 June 2004 4:41:54 AM(UTC)
#4 Posted : Wednesday, 2 June 2004 4:45:39 AM(UTC)
Thanks paul,
my ute is sports a mildy worked 308, just got flat top pistons and the block shaved for higher comp, it has a mild cam and electronic dizzy, exhaust, and as mentioned before is has the powerglide behind it so would you recomend #78jets to b
#5 Posted : Wednesday, 2 June 2004 5:30:01 AM(UTC)
Yes, what I'd do to start with (pretty cheap stuff here for big gains) is:
1) Change to #78 jets (do not go bigger, these are available from CSC in Burwood, NSW)
2) Reset float level (see my last post)
3) Increase needle/seat assembly to a edelbro
This page was generated in 0.066 seconds.
