WBman Offline
#1 Posted : Sunday, 29 January 2012 7:32:30 PM(UTC)
WBman
Hi can anyone help I have just installed a power steering box in my ute, when we cranked it up for the first time oil poured out of a hole in the top of the box, after having a look at another box it has a grubscrew in it, can I just screw a grubscrew in or is it a special screw?
Edited by user Sunday, 29 January 2012 7:36:38 PM(UTC)  | Reason: Not specified
KeithA Offline
#2 Posted : Sunday, 29 January 2012 8:14:43 PM(UTC)
KeithA
If you can find a grub screw that fits, screw it in. All that does is plug the hole which has an adjustment screw inside.
mmazz30 Offline
#3 Posted : Sunday, 29 January 2012 8:55:18 PM(UTC)
mmazz30
You have been a member since:: 6/01/2007(UTC)
From what i remember there isnt any adjustment on the P/steering boxes and trying to adjust what is in there stuffs them up.
I could be wrong
#4 Posted : Sunday, 29 January 2012 9:12:24 PM(UTC)
I could be wrong
Basically correct. These adjustments are for initial set-up on the bench using accurate measuring techniques. Attempting adjustments on-car will lead to drama.
KeithA Offline
#5 Posted : Sunday, 29 January 2012 11:29:06 PM(UTC)
KeithA
I should have made it clearer as you have Dr Terry, that although there is an adjustment screw in there, do not touch it. He was only asking if he can use any grub screw that fits in the hole.
This page was generated in 0.099 seconds.
