gas
basketcasebear Offline
#1 Posted : Friday, 3 February 2012 8:10:04 AM(UTC)
basketcasebear
hey yall,
my gas mixer has gone haywire,
engine starts on gas, [primer] will run on gas if button is held in on mixer,
q, do they gunk up? can one pull them apart and clean them? or run soapy water thru em?
or does one just buy a new one from ebay?
bcb
DOH!!!
#2 Posted : Friday, 3 February 2012 8:15:47 AM(UTC)
If it only runs when you hold the primer down, then I'd say you've got a split/torn/holed diaphragm in the mixer. Have you had a backfire lately?
You can buy replacement diaphragms & rebuild it yourself with basic hand tools - even on the side of the road.
#3 Posted : Friday, 3 February 2012 8:23:18 AM(UTC)
basketcasebear
yep com nut
had a couple backfiresers
the inner metal round cap with slots out of it, fixed to the rotor button, to do with the electronic ignition got loose, and was wobbling around, mobile mechanic used superglue to fix,
runs ruel good on petrol now,
so wadda ya reckon, new mixer? or repair?
bcb
DOH!!!
peter_flane Offline
#4 Posted : Friday, 3 February 2012 10:22:22 AM(UTC)
peter_flane
Is it an Impco mixer? Generation I or New Generation? Pop into a gas place, and you may find one that is helpful, and sell you a new mixer at a good price. I have been lucky with the last two I have dealt with, and they have both been very helpful.
#5 Posted : Friday, 3 February 2012 2:08:11 PM(UTC)
basketcasebear
hey peter,
it is impco, in a 79 308 out of a vb commy.
dunno which type it is.
bcb
DOH!!!
#6 Posted : Friday, 3 February 2012 4:18:05 PM(UTC)
Off a commodore, it's likely to be an Impco 300A like 99% of commodore V8 conversions are.
Here's a couple of ebay listings to help with ID:
The usual snorkel arrangement: http://www.ebay.com.au/itm/150749308441
And a clean new one: http://www.ebay.com.au/itm/170614864647
If it is a 300A, then you can buy a rebuild kit with a new diaphragm from this mob in Victoria:
http://www.bluelpg.com.au/tmcart/products.php?195
Ot to get you out of trouble, you can buy a 2nd hand one, and simply copy the "tuning" settings off your one, and that will get you going at least.
#7 Posted : Saturday, 4 February 2012 3:00:38 AM(UTC)
try to avoid using second hand converters, unless they have been removed form a running car, converters only last about 6 months off a car before the diaphragm dries out, also people usually only take them off if there stuffed!!
re-build kits are ok there easy things to fix, personally i think a new converter is the best way to go
Jonesy77 Offline
#8 Posted : Saturday, 4 February 2012 7:55:42 AM(UTC)
Jonesy77
G'day all this might be an expensive way to go but if you have a dollar or two there is gas injection which can give you more power and run cheaper than the traditional way gas is runs,one of the guys at work has fitted it to his hg and is running around 8-9 litres per 100 on a 327, but if yur budget is tight i would recomend that you go new i think that the converters are relitivly cheap and you don't have to worrie about is it going to play up in the future,just an idea to throw into the mix.
cheers jonesy
Happiness is not a destination but a way of life (so drive a kingswood)
#9 Posted : Saturday, 4 February 2012 12:19:20 PM(UTC)
basketcasebear
thanks everyone,
i got the part wrong, it is the converter that appears to be cactus, but she runs when the button is pushed on converter, not mixer,
me thinks a new converter is the best way to go.
bcb
DOH!!!
#10 Posted : Saturday, 4 February 2012 2:10:44 PM(UTC)
If the gas guy does't have an impco handy, the "Aussie B2" copy of the popular impco is a cheaper option that's just as good for a daily.
#11 Posted : Sunday, 5 February 2012 2:55:53 AM(UTC)
Originally posted by basketcasebear
thanks everyone,
bcb
i knew what you ment, yes a new converter is the best move
#12 Posted : Sunday, 5 February 2012 11:25:57 AM(UTC)
basketcasebear
hey yall,
put new dizzy cap on today, but having truble getting bosch rotor for elec ignition, when mobile mech changed oil and filter in t400, he said there was nothing to adjust in auto when pan is off??
well today she suddenly started slipping, not changing to top gear?? [ after 20klms] never missed a beat before.
so i put another litre of dextron3 in her, and she ran a little betterer?
i knew it was a mistake to let a mechanic touch her??
last time i did, they put the wrong!!!! air filter in the transit diesal, [when she was a diesal] and it never ran properly again. cost me a fortune.
tell ya if it wasnt for ewes blokes, i would be walking.
thanks heaps
bcb
DOH!!!
